EZ Glider Elec.
EZ Glider Elec.
I am getting a EZG from tower soon and have a few questions.
1; With the stock setup can I use a 3s A123 pack, CG taken into consideration?
2: Original prop going to work within reason as a strarting off point ?
3: Esc going to work or will I have to up grade ?
I am somewhat new to "elect power" but have done a fair amount of research.
I currently have the EZ glider, Electron 6/ Hitec Eclipse 7. Triton 2
Any help greatly appreciated.
Aloha, Les
Aloha, Les
RE: EZ Glider Elec.
if you give some more info about the plane, it would be easier to help you out
if your current setup is 3s, then no you will not have to change the esc or the motor as long as there isn't too much of a weight penalty going up to the a123 packs.
The a123 packs are 2300mAh per cell, and probably around 200 to 240g or there abouts. How much does your stock pack weigh?
also about the prob, yes it will work fine unless you have a weight penalty with the new packs.
