Noob Question Again
Noob Question Again
Hi,
I have another noob question that I have spent a day trying to answer on my own(literally). The problem is, I need to get Pic1 to connect into Pic 2, any ideas on what to buy/use to get those two to connect? Changing the JST is not an option and I have no clue what the other connector is called.
Many Thanks,
Sky
Many Thanks,
Sky
RE: Noob Question Again
if you wanted to switch to the JST, and from what I am getting you do. Just clip that other lead off, solder on a JST lead and heat shrink the exposed solder joints.
I've never seen that other connector, maybe someone else has and knows of where you can get an adaptor.
