E-flite 60 amp ESC question
NC
The E-flite ESC I just purchased is programmable.
The default setting includes a 70% voltage cutoff.
It can also be programmed for a 3-cell cutoff or a 6-cell cut off among other settings.
My battery pack is a 3S2P pack. That means it has a total of 6 cells.
Basically, it is two 3-cell packs joined in parallel. Voltage is 11.1v and amperage is doubled to 4400 mah.
Which is the correct setting for my 3S2P pack?
RE: E-flite 60 amp ESC question
NC
Thanks for the info.
Do you now what 70% of what? Is it 70% of 11.1v? That would be 7.77v which is too low for a cut-off.
I think I will stick with the 3 cell set up just to make sure.
Thanks again.
Thanks again.
When a pack includes paralleled cells like your 3s2p (6-cell) pack, it is essentially a 3-cell pack for all practical purposes.
The 70% refers to 70% of battery starting voltage. You can see from the graph that on any LiPo pack, about 75% capacity will measure about 3.7v/cell or 11.1v (unloaded) on your 3-cell pack. A fully charged pack is 4.2v times 3 cells = 12.6v. (unloaded)
Working backwards...70% = Xv/12.6 so Xv = 12.6 * .7 = 8.82v
Divide 8.82v by 3 cells = 2.94v per cell (under load)
This is a safe cutoff voltage as your pack will never go under 3v per cell when the motor is running. After you land, you will find that the pack voltage is much higher than 3v per cell.
I'm not sure which setting gives you the longer run time; 3-cell or 70%. It is likely a setting used for heavy 3D flying so the motor is less prone to turn off until the battery is really depleted.
MI
Another note, if you use the 70% setting and fly with a partially charged batt it could be ruined because it is 70% of starting voltage.
God Bless,
Jay
God Bless,
Jay
NC
Greg,
Thanks for the information. One thing about this hobby..... I am always learning something new!
I will try it both ways and see if there is any appreciable difference in flight times.
