Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Sebart Sukhoi / Hacker motor ?
Old 10-07-2008, 07:50 PM
baxternick
My Feedback: (19)
baxternick's Avatar
Default Sebart Sukhoi / Hacker motor ?
I am looking to purchase a motor for a sebart sukhoi 30e and wanted to know what the difference is between the hacker 30-10Xl and 30-8Xl is? I can get a 8XL for a good price used, but is it going to pull the airframe alright? If anyone else has some other suggestions please chime in.
Old 10-12-2008, 10:30 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default RE: Sebart Sukhoi / Hacker motor ?
The difference is two turns of wire per stator pole. The 8XL will have a higher Kv rating, which means it will try to spin the propeller at a higher RPM when given the same voltage. You will need to run a bit smaller prop to prevent overloading the motor than you would on the 10XL.
Old 10-26-2008, 08:37 PM
Jimmy Hoffa
Jimmy Hoffa's Avatar
The 10XL will work better on the Sukhoi because you can run a larger prop. Use a APC 14x7E prop and a 3 cell battery.
Phillip
Old 12-05-2008, 07:57 PM
Harley Licht
Does anyone have any ACTUAL current measurements using a Hacker A30-10XL on a 14 x 7 with a 3S1P 2100-2500 battery pack?
I am thinking of using some of the Brand New Thunder Power ProLite V2 packs which are 2600mah at 20C for a constant
amp rating of 52amps... and a 30C burst rating of 78amps.
I know I can get by with good throttle management with these packs, but I would be very interested in knowing the results
of ACTUAL measurements with this motor/batt/prop combo. (or similar batt equivalent such as the Flightpower 2500 or TP
Extreme V2 2200mah etc)
Thanks in Advance for your response(s).
Harley
