Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
help choosing motor
Old 03-18-2009, 06:52 PM
jt182
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default help choosing motor
TURNIGY AerodriveXp
I am looking at this motor for a bridi aircruiser 25, est. wgt. 3 1/2 lbs any in put would be appreciated.
I beleave this would give me 75 watt's per lb
Model: TR35-42B
Input Voltage : 7.4V~14.8V (2~4S Li-po)
Kv : 1250 rpm/V within 10%
Current capacity : 45A/30s
Dimentions : 35mm X 42mm / 1.38in X 1.65in
Shaft diameter : 4mm / 0.16in
Weight : 132g / 4.66oz
Number of poles/magnets : 14
Recommended model weight : 600~2000g / 35~81oz
Power equivalent : .30 to .35 IC glow engine
Stator Dimentions: 28x20mm
jt182 is offline
Old 03-21-2009, 10:16 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: help choosing motor
If you reduce the optimistic rating by 25% or so... these are good motors. I think that if around 250W is enough for you, that motor will do very well - maybe even 30A and 300W - but the 45A burst rating is way too much! As for HC bragging that this motor is the equivalent of a .30-.35 IC motor (that's about 600-700W)... forget it.
Dr Kiwi is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
