Need to change prop shaft to opposite side
CO
All,
I have a turnigy 2830-1000 and I need to move the shaft so it will extend out the opposite side of the motor for my application.
Is there an easy way to accomplish this?
It has a C clip on one side and an allen screw on the other side of the casing I have removed them both.
So far I have tried to push the shaft through using a vice but it didn't move so I stopped before I bent something.
Thank you in advance
TN
RE: Need to change prop shaft to opposite side
They can be VERY tight. Remove the bell and shaft as a unit... then, make sure you support the whole circumference of the rear of the bell with a hardwood block with a hole in it for the shaft, and with the vice, press the shaft back through.
