Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Exceed Monster Power 160
Reply
Old 12-06-2009, 05:18 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Exceed Monster Power 160
I am using a Tru Turn on my T-6 without any problem. Has a 20x15 prop. I just drilled and tapped a hole for the bolt.
ID:	1328432   Click image for larger version
ID:	1328433   Click image for larger version
TLH101 is offline
Old 12-06-2009, 05:52 PM
RR24
RR24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good Terry
RR24 is offline
Old 12-07-2009, 12:23 AM
maverickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can't believe the cheap price I paid for this motor. So no one has seen any problems yet with loose magnets or anything? I've searched and can't find anything negative on this line of motors.
maverickma is offline
Old 12-07-2009, 12:47 AM
DaveFlynn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OH, Yes. Both of mine have been completely rebuilt. Re-soldered 12AWG wires, Re-glued magnets, new bearings and shaft. On one the stater came loose and had to be glued back on. As long as the case doesn't get bent or the coils damaged, it's easy to rebuild. McMaster-Carr has class 5 bearings and metric hardened drill blanks. Always buy 2 or 3 shafts, because technically they are the same size as the bearings and sometimes don't slide through. Bearings have a tolerance of -0.000 +0.005mm and the drill blanks tolerance is -0.005 +0.000mm. So there could be 0.01mm difference which slides in easy or 0 difference which would need to be pressed (don't), but mostly they slide with a little push.
DaveFlynn is offline
Old 12-07-2009, 12:56 AM
maverickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: DaveFlynn
Oh boy. So how many flights can I expect before I need to rebuild? Is it safe to stick this in a shiny new 27% GP Edge 540 or should I use it in a more "disposable" plane?
Do you have part numbers from McMaster so I can have the rebuild parts on hand? I like to be prepared.
Old 12-07-2009, 01:11 AM
  #31
DaveFlynn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think all of my problems have come from a less than optimal landing. Before each flight pull on the prop and rotate slowly, if it doesn't feel smooth then it's time for new bearings.
Old 12-07-2009, 10:02 AM
  #32
maverickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: DaveFlynn
Ok cool, sounds like you haven't had a catastrophic failure in flight which was my main concern. Routine maintenance is important...thanks for the tip. I'll use it to check all of my motors now!
Sorry to be a nudge, but can you post links or product numbers to the rebuild items??
Old 12-07-2009, 05:34 PM
  #33
DaveFlynn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New 8.00mm shaft is McM P/N:2900A358
I don't remember the bearing P/N.
Outside Diameter Width Dynamic Radial Load Capacity Range, lbs. Each
12 mm 3.5 mm 6 to 250 lbs. 7804K115 $7.21
14 mm 4 mm 6 to 250 lbs. 7804K116 6.57
16 mm 5 mm 251 to 500 lbs. 7804K117 6.13
Old 12-10-2009, 03:02 PM
  #34
maverickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do we know if the stock E-Flite prop adaptor will fit on this motor???
I received mine today...it appears to be a nice quality motor. I'm considering purchasing a 2nd one just to have on hand for a future project, because I doubt that $50 pricetag will last. I don't even have an airframe for the 1st one at this point, but its hard to pass up a deal!!!
Old 12-11-2009, 03:35 PM
  #35
maverickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: maverickma
So I called Exceed RC "customer service" (and I use the term loosely) " to ask the same question. I asked if I could purchase a spare adaptor, and they said they had not ordered spare parts because it was the holiday and they did not want to order spare parts. I asked if the EFlite Power 160 adaptor would work and he told me he wasn't sure, but I could try it. Ummmm....wuh? Who'd on 1st...what's on 2nd..I don't know?
I could have gotten more useful information speaking to my left nut sack. In terms of service, you get what you pay for. May not buy that 2nd one after all. Comparative Rimfire motor is only $80 more and they are very helpful when I have questions. Still a good deal...hopefully it won't explode on the maiden flight.
Old 04-12-2010, 08:43 PM
  #36
highhorse
highhorse's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any more feedback please from someone using 10s or 12s and pulling 60 amps plus ??
highhorse is offline
Old 04-12-2010, 08:50 PM
  #37
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just put mine in a Top Flite 1/5 Mustang. Running 10s (5s x2 5000mah) with a 20x13 prop. Pulling close to 78amps at full throttle, but at about 95%, it drops to the mid 60s. 5 min flying time at about 60-70% throttle used 3000mah from a 5000mah pack.
6400 rpm, and about 3k+ watts.
TLH101 is offline
Old 04-14-2010, 12:19 AM
  #38
highhorse
highhorse's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have u been using this way for a while? I'm curious about the longevity of this motor. It seems too inexpensive to be reliable ??
Old 04-27-2010, 08:50 PM
  #39
highhorse
highhorse's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone else been using this motor for a while?
Old 07-28-2010, 06:58 PM
  #40
rtec
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gee WIZ you guys act like you are buying a $350 dollar motor!
it's $49!
I have way over 150 flights on my monster 60 and several dozen flights on my 160
The 60 got planted at lesta foot into the ground, Dug it out, got it home, throw it in a bucket of water to loosen up the ground, then took the garden hose to it and washed it off,sprayed it with some WD40, throw it in a new plane and that was 125 flights ago.
stop over thinking everything..
bob
oh ya, why in the hell would the guy at Exceed know if e-flite's parts would fit? or why would he even care? Call e-flite with the same question and see what kind of an answer you get from them.. lol
rtec is offline
