supertigre power or not?
MO
thinking about going electric on a park flyer small su-31 ect .... , is the supertigre line a good choice and what about 9g size servo
MO
RE: supertigre power or not?
now : Have the electrifly su-31 and need a .10 motor to turn 10-6 prop other post leads me to think the supertigre is a little weak for this size prop and plane. need help
TN
Yes, I reviewed the Supertigre .10 and was not impressed. If you need a 10x6 a Suppo A2217K/8 is a good cheap solution:
10.7v, 20.80A, 222W, 9030rpm, 51.3mph, 1135g, 39.37oz, 5.11g/W
I don't know exactly what your requirements are, but obviously if you need more speed than this, you need to go for a more powerful motor.
MO
the su-31 calls for the electricfly .10 with 35 amp esc 1500mah battery and 10-7e prop is the supertigre .10 close to this motor, was going to try st.10, 30amp esc and 1800mah 11.1 battery
TN
My concern about the Rimfire .10 is the same as my concern about the ST .10... both are over-rated as far as their power handling capabilities go... I found that the ST .10 is good for only about 200W.....the Rimfire .10 says 325W continuous... yeh, right!
MO
well if there about the same I will be ok for power at about 1/2 to 2/3 the price of electricfly and my local dealer carries the supertigre line. Plug and go is that i'm looking for, not much time to solder and buy part to match difference products
TN
ORIGINAL: twinflyer
MO
the plane wt should be 27 to 31oz with a 10x6 gws 11.1v you got 36.34 oz thrust which should be ok, i'm not sure on temp in your chart the red shows max but 92 you give smoke. but whats the normal range, or safe zone so to speak? P.S. thanks for all the information
TN
If a motor gets to 60C by the end of my five short bursts as a series, that is as hot as I'd ever go. A moderate length series (about 80 seconds running in total) with the 10x6 got it to 49C so that is just okay in my book.
