Dumb Brushless motor question
PA
I just built a custom electric RC snowmobile.
It has a 400watt 480 size brushless motor. I noticed it runs faster backwards then forwards. this indicates to me that the motor is running in its non-optimal direction.
I can't beleive there is no info on the web about this.
If I look at the motor from the front - where the shaft comes out, the motor spins counter clockwise. I think it should spin clockwise to be optimal.
Is this true? Can anyone help?
I use the stock gear box with 4 gears. So, if I want to spin the motor in clockwise rotation, I need to remove a gear or use a belt drive etc.
My Feedback: (9)
RE: Dumb Brushless motor question
Direction of rotation means nothing to a brushless motor since it is accomplished electronically in the speed controller. First do a physical check. Does the motor spin freely or at least with the same drag in both directions? If not you've probably got a damaged bearing. More likely the problem is in the settings on the speed controller. If the motor is an in-runner set it to the lowest selection, if an out-runner try the highest. If neither makes a difference try one in between.
Hope this helps. I'm an airplane guy, but motors are motors.
Walt
Walt
PA
Ok, thanks Walt
I am an airplane guy too. Cars are new to me but like you said: motors are motors. I purchased a Castle Creation Sidewinder ESC and it is programmable but I just used the default settings (didn't want to sp[end the time fooling with programming it).
The Castle Creations directions said if you are using a Futaba radio (which I am), to reverse channel 2 (throttle) which I did. I wonder if maybe I should not have reversed this and should just have programmed (using the radio - full, reverse and nutrual) it the way it was. Maybe it thinks forward is reverse and is not providing as much current to the motor?????
My Feedback: (9)
I am not familiar with escs that offer reverse, but I do know that you have to reverse the throttle channel on futabas for a/c. I imagine it is the ame for cars.
Walt
Walt
PA
Ok, thanks again Walt.
I got it all figured out. I spent some time to read the manual that came with the ESC a little more thoroughly and was able to program all 9 settings for the Castle Creation Sidewinder using just the radio transmitter and now it really moves.
This was also my first high power car ESC with reverse.
