Max voltage for a Hitec servo
Dear Sirs: My question regards the maximun voltage that a Hitec 7955TG servo (non high voltage) should be ran at. I'm am wondering if a Li-ion at 8 volts would be too much. Thanks in advance. Jerry |
RE: Max voltage for a Hitec servo
You will run the risk of burning it up! That is a 33% increase over it's recommended operating voltage. Because the motor resistance remains constant the current drawn will mostly double. Not knowing the normal operating current makes it impossible to calculate. If you plane mean anything to you I wouldn't run the risk of having the servo fail!!!
1 Attachment(s)
There are in general couple different ways to make this in a safe manner:
1. Use an effcient integrated DCDC Converter. Cost is about 10-15 USD per servo and that leads people to abandon the use of old servos and purchase the new so called 'high-voltage' servos; many makers have them in the catalogs. This is indeed the best especially if you are aiming at high speed servo performance, for example for F3A or similar demands. 2. The cheapest what I use is on the attached file and it cost about 1-2 USD per servo by using linear regulators '7806' and couple capacitors. It will take you couple hours to solder those components. NOTE: There isn't any circuit here which checks now low the voltage of the LiPo has gone; it is god t keep the LiPo aways charged and ballanced so to void their damage ineed frm overdscarge. BR, Nick |
Or you could listen to the source... That would be Hitec..
and according to them, unregulated LiPo or LiIon (2S) is absolutely fine |
