RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Brushed/Brushless motors, speed controls, gear drives (http://www.rcuniverse.com/forum/brushed-brushless-motors-speed-controls-gear-drives-123/)
-   -   durafly se5a power drain (http://www.rcuniverse.com/forum/brushed-brushless-motors-speed-controls-gear-drives-123/11209835-durafly-se5a-power-drain.html)
bondspyguy 08-28-2012 07:40 PM
Hope some one can help.I am new to electric and purchased the durafly se5a been flying for a few weeks then the batteries turnigy 1800mah went from 12 min flight times to 7 then 4 now only last for a minute and no power I even tried a brand new battery nano tech and I got the same.I. tried changing radio and receiver with no joy.can the speed controller or motor be causing this battery drain.and does the controller need to be reprogrammed or something.I am a loss and hope someone can help please.....my power loss is the motor only I still get all servos work ok.
jzrf6c 08-29-2012 05:11 AM
RE: durafly se5a power drain
Try reprogramming the controller. When you do, remember to set the throttle trim down. Also, if you have another ESC give it a try (swap them). It could be the motor. If it gets hot or in a crash it can be damaged. If you get the same results with a different (same specs) ESC I'd say your motor is bad.
bondspyguy 08-29-2012 12:45 PM
Sorry but how do you reprogram the esc
Gohmer 08-29-2012 01:12 PM
What is the voltage reading at the battery connectors after charging? Sounds like a charger problem to me.
bondspyguy 08-29-2012 01:15 PM
They all show 11.4v fully charged then drain to around 9 within a minute
Gohmer 08-29-2012 01:32 PM
Should show 12.6 V fully charged. What charger are you using?
bondspyguy 08-29-2012 02:11 PM
Hi thanks for the help I am using the turnigy accucel 6 and I balance charge them each time
Gohmer 08-29-2012 02:26 PM
I'm not familiar with that one. Sounds like it's set in a storage mode. You need to get it set somehow so it charges to 12.6v. That's your flight time problem.
bondspyguy 08-29-2012 02:56 PM
Ok I will check it out thanks again for the help.....turnigy are from hobbyking just to let you know .thanks again hope I can sort it out 1 minute of flight is not good [:@]
