RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Brushed/Brushless motors, speed controls, gear drives (http://www.rcuniverse.com/forum/brushed-brushless-motors-speed-controls-gear-drives-123/)
-   -   Motor Suggestions MoJo 60 (http://www.rcuniverse.com/forum/brushed-brushless-motors-speed-controls-gear-drives-123/11315673-motor-suggestions-mojo-60-a.html)
OldRookie 12-01-2012 06:33 AM
I am trying to figure out which electric motor to put in my MoJo 60 MoAss. The plane is at 110 oz ready to fly with a Saito 100 setup. I would like to use a 5s pack swinging a 16 X 8 to 17 X 8 prop, and 200+ watts/lb. This should be equal to or more powerful than the Saito 100. The electric setup will probably be heavier than the Saito 100 setup.
The problem I was having is to choose between a 60 and 90 size electric equivalent. It seems as if the 60 size motors cut off at about 7 lbs maximum for 3D use. The 90 size motors add a fair amount of weight, but would be more than enough power. I would like to get the EP setup right the first time, as this size setup gets pretty expensive.
Some of the motors I have been considering are:
Motrolfly DM4315-500 http://www.subsonicplanes.com/Motrolfly_Motors.html
E-Flite Power 60 http://www.e-fliterc.com/Products/De...odID=EFLM4060A
E-Flite Power 90 http://www.e-fliterc.com/Products/De...odID=EFLM4090A
ElectriFly RimFire 80 or 120 http://www.electrifly.com/motors/gpmg4505.html
If you have any recommendations or criticism for one of the motors I listed, or any other brand, please let me know.
Thanks in advance,
Greg
blvdbuzzard 12-01-2012 08:59 AM
RE: Motor Suggestions MoJo 60
I am using this motor in a Formula 3D. It weighs in at about the same as yours ready to fly.
My setup
Motor
http://www.hobbypartz.com/96m606-big...030-400kv.html
Battery
http://www.hobbypartz.com/98p-25c-5500-6s1p.html
ESC
http://www.hobbypartz.com/07e09-proton-80a-opto.html
With BEC
http://www.hobbypartz.com/07e08-proton-80a.html
I run a APC 18X8 prop. It is about max of the 60 amps at full throttle static. I have not hooked up a scale to it but it has no problems pulling out of a hover.
Buzz.
