O.S OMA-5025-375+OCA-1100HV+OCP-1 Help to set!
Good afternoon, I write from Argentina and I am needing some help from fellow modeler that has the OS set the engine OMA5025-375 and OCA-1100HV Esc.
I purchased the developer OCP-1 from the same company to schedule the whole engine, but I honestly do not know much about it and I prefer not to make any errors that may result in the loss of any of the components. Does anyone have this team and I could facilitate the programming data to configure my set? This will be mounted on a model "Epsilon 90" CAMODEL company, which previously was using an ASP .91 I will use Batteries are "Zippy Compact 3700mah" and 25C of discharge and APC 16x8E. From already thank you for your help. Greetings to all and good flights! PW: I apologize for my basic English. |
RE: O.S OMA-5025-375+OCA-1100HV+OCP-1 Help to set!
Hi Aerofede 91,
I am not familiar with the power system you have, but you can get the answer to a lot of your questions by downloading "Drivecalc" a free, online program for predicting performance. It's available in a number of languages. It's definitely worth learning how to use for any e-power pilot. Hope this helps. As for programming the ESC, in most cases the default (factory) settings will work. Be careful with the Zippy compact line. I recently purchased several and they seem to have a very sharp voltage drop and do not recover quickly. Walt |
Try the electric pattern forum.
