LOSI 454 IN T-maxx OR AXIAL .28rr IN T-maxx,,,WHATS BETTER
please tell me what you guys think
1.) Mount the engine.
2.) Take out plug. Look down in engine, rotate flywheel to point where piston is at absolute bottom position. Scratch a small mark in your flywheel at 12:00. This way you know where bottom-dead-center is. The piston needs to be at this position during cool-down during break-in.
3.) Before starting, ideally wrap the cooling head in alu foil, and use a hair dryer to heat it up to 225F or so. Start the engine, monitor temps. You want the engine to be 200-230F. Slightly lean the HSN if necesary if it's just way too rich - which it may be at factory settings. Once you're got it so it's at least running, plop the car on the ground and drive around at no more than 1/4 throttle blips - vveeeerryyy slowly back and forth. Do this for a few minutes with the engine in that temp zone just over 200.
4.) Then, shut down engine. Rotate your flywheel to the scratch-at-12:00 position, and let the engine cool completely. Read a magazine or play with a yo-yo or whatever while it cools completely.
5.) Repeat ten times or so over 3-5 tanks. You may need to lean more or less, take off alu foil, or whatever it takes - the whole point is to get the temps up to 200-225 and let it cool completely, and to repeat 10 or so times. This is called heat cycling, and is the SOP for most people for break-in(though there are others..)
For the first half gallon after that start leaning it so it clears out the fuel and runs more crisply, but lay off full-throttle passes too much. Once half a gallon or so is through it, as long as temps and performance and sound and smoke and everything is alright, then IMO letter' rip... Once it's broken in, I recommend an OS A5/#10 plug for best performance - though the idle won't be as stable with a cold plug. IMO these SH engines make a good deal more power with a cold plug too. Run cooler too..
The Dynamite Big Red 28, Losi 454, or LRP Spec 3 would all be fine. Try a Picco if you'r confident about getting it running right.
I don't know how pipes work on TMAXXes, but a good pipe - JP-2 - to mate to a cheap Losi 454 might be an idea.. I wouldn't just go buy a more expensive engine cuz you have a few more bucks..
Never pay attention to manufacturer performance claims for nitro engines.
But yes, the LRP is prettier.
well i found a dyno of the spec 3 and it was impressive. but i think im going to get the lrp. i know i changed my mind 3 times now from .28rr 454 to lrp, but the lrp will go with the color scheme of my t-maxx. the orange head of the losi wouldnt go with purple and blue,,,lol
I wouldn't buy an engine based on the color of the head, but thats just me.
the engines are made by SH (i think?) and rebranded. if you want that engine with a blue head for significantly less than the lrp costs get the SH .28
SH makes the Dynamite/Mach engines, LRP, XTM, and a few others. About the only discernable difference is the branding on the crankcase, and perhaps the port timing. I would have to get each of these engines in my hands and degree them to determine if the timing is identical or not.
thats true, but how fast do you guys think a .28 will go with a single speed tranny in a t-maxx,,,i though with the 24/7 i had in it that it was doing at least 40, but could be wrong
The JT Hybrid chassis uses a center differential as opposed to a transmission.
Unless its been modified to use a transmission you will need to use very heavy diff lube in the CD cup or you will not get the wheelies you are looking for.
There all Team Associated engines they make SH,454,427,LRP,MACH.26.28 and others. Also with that chassis it's not going to wheelie. the chassis has a center diff not a spool. Change your ctr diff oil to a very heavy wt, or your front tires will balloon and slow the truck down.what gearing are you planning on using?Go with the 454 or the 427 Dynamite/Team Losi engine.heres my tmaxx/truugy
I know very little about the T-Maxxes so I didnt know it uses a Center Diff. I suppose it would help if I read a little closer, also.
i have a 15t clutch bell and a 64 spur i beleive,,,but man i really wanted to do wheelies with it, i mean yeah speed is fun but i also wanted wheelies
There is a lot more to it than this, but here is a quick explanation.
A center differential has two output pinions/shafts compared to a transmission which has 1 solid shaft or spool. The two output shafts can work independently of each other by means of spider gears inside the diff cup. If you notice there will brakes on the front and the rear of the center differential. That is because you have to stop 2 independently moving shafts as compared to 1 solid shaft which would only need 1 brake setup like a standard transmission. Light wt oil/lube allows a very free action of the spider gears and a very independent action of the output pinions/shafts. Heavier oil/lube will tighten up the action of the spider gears and reduce the independent action of the outputs.
The center diff acts just like a limited slip front or rear diff. It will send the power to the wheels with the least amount of traction/grip. When you accelerate the rear squats, the front raises and with a light wt oil in the diff almost all the power will go to the front wheels because they now will have less traction than the rears which = no wheelies. The heavier the diff oil/lube you use in the diff cup the more locked the spider gears inside the diff cup become and power output from the center diff to the front and rear diffs become more equal in proportion to the wt of oil used.
Some 1/10<sup>th</sup> scale diffs use 4 spider gears, others like 8<sup>th</sup> scale use 6 and 8 spider gears.
More spiders’ means less wt oil can be used to obtain similar results as heavy wt oil and less spiders because there is more surface area of gear teeth to act against the oil wt.
Something as simple as plumbers putty or silly putty can be used in the diff cup or a very heavy diff lock lube to almost lock the spider gears together and act very similar to a solid output shaft to obtain the wheelies you are looking for with a center diff.
Some will go as far as filling the diff cup with JB-weld or epoxy to completely and permanently lock the center diff in effect making it a solid shaft/spool.
