If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 12 of 12
  1. #1
    nazUK's Avatar
    Join Date
    Jun 2010
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Help on how to customize cut Starter Box
    Hi Everyone
    Right I bought my first Starter Box and to my surprise it does not fit my truck.
    Very annoying and it's suppose to be universal/multi whatever they call it, "what a load of crap"
    Anyway been on the net trying to see if other people have had the same problem as me and I did find quite a few. What I also found out is that a lot of guys have adapted there boxes by cutting them and lifting the wheel to make it fit or shall I say work.
    My question is has anyone done this...
    How did you go abouts doing it?
    What tools did you use?
    Any tips or techniques I should use?
    Also did you have to cut the chassis too?
    I have a fair idea what to do but want to make sure I do it right before I start.
    Thanks in advance
  2. #2
    nazUK's Avatar
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Help on how to customize cut Starter Box
    Forgot to mention...
    It's a "Kyosho Multi Starter Box Pro 2.0 (KYO36209)"
    My truck is a HSP Savagery Pro also known as Redcat Racing Landslide 21.
    But I've modded it so much it's not even stock anymore
  3. #3
    8MILLSNIPER007's Avatar
    Join Date
    Sep 2009
    QUARTZ HILL, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I do not have any experience with that box, but I do have a XTM universal starter box and for my truggies I had to actually put some spacers under the motor/wheel assembly in order to lift it up high enough to make contact my truggies flywheel.  Then came problem #2, The slot in my chassis was too small.  Easy fix would of been to go out and buy a larger flywheel but I use the Works clutches so that was a no go, what I did was make the slot a little bigger and wider on my chassis by using a dremal with a carbide burr.  Works great, but then came problem # 3 lol.  I could no longer start my onroad cars cause the wheel was too high, so instead of taking the box apart everytime I wanted to run onroad I made a frame out of wood that fit on the top of my box and also fit my onroad car chassis perfect, so now it is a piece of cake to start all of my vehicles.
    If you dont have access to a lathe to make spacers you could just stack washers underneath the starter motors and wheel to raise it up in the box.
    Good luck
  4. #4
    nitroexpress's Avatar
    Join Date
    Oct 2006
    Sonoma, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    nazUK went from a stock .18 engine to a .28 roto-start engine. New motor mounts caused the engine to sit higher and therefore make minimal contact with the starter wheel. A larger flywheel should solve the problem without the need to modify the starter box.
  5. #5
    Join Date
    Sep 2009
    QUARTZ HILL, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nitro- I thought I mentioned that a larger flywheel would be the easiest fix? Unless he is like me and uses an adjustable clutch
  6. #6
    Join Date
    Oct 2006
    Sonoma, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: 8MILLSNIPER007
    I missed that tidbitof information. + to you.
    BTW, he bought a Duratrax 41mm clutch. So I guess the problem is solved.
  7. #7
    nazUK's Avatar
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys
    Sorry for the late reply but like nitro said yes I bought a 41mm flywheel, haven't got it yet as it's on route.
    Wouldn't be too keen to say yet problem solved as you never know with these things you try something and then hey presto another problem pops up. But yea without a doubt in theory this is a great solution if it works, may need to grind the chassis hole as it looks a bit small but will give you guys an update in a week when I get the flywheel.
    Thanks for all the tips and help anything else you think I should know please keep it coming
  8. #8
    nazUK's Avatar
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for letting me know how it went with your box 8MILLSNIPER007 hopefully may not need to touch my box but like I said in my previous message all depends on flywheel when fitted.
    Will keep you guys up to date
  9. #9
    Join Date
    Sep 2009
    QUARTZ HILL, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I hope it works out for you...Best of luck!!  If you do end up needing to mod the box(which I dont think you will) but if you do let me know and I can take some pics of mine...
  10. #10
    nazUK's Avatar
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea thanks mate will do..... Much appreciated
  11. #11
    nazUK's Avatar
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Right thought I give you guys an update been a bit busy cause of work so didn't get around to fitting the flywheel sooner.
    Anyway finally fitted the larger flywheel and "Wow" what a difference, it's a bit late in the night so can't test the flywheel working but as it stands visually it so much lower, but not low enough that it sticks out or right next to chassis hole, sits a good 5mm away.
    It looks very likely with the bigger flywheel it may work without any modding to the starter box the only problem I have noticed which was something mentioned on another forum is the chassis hole is not big enough and one side of the edge is touching the starter wheel. So it looks like I may need to make the hole under the chassis bigger from one side, which to be honest isn't too bad as it's an easier mod to do rather than modding the starter box.
  12. #12
    Join Date
    Sep 2009
    QUARTZ HILL, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Glad to see it's working out for you man! Just dremel the side that hits open until it clears and your all set!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
