Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Blur engine madness
Reply
Old 09-13-2012, 02:29 PM
davidgp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blur engine madness
The only way I can keep the enigne running is to set the high speed needle WAY rich, like 6 turns out. I can't find a low speed needle. It will run ok until the engine heats up, then it dies. I'm sure someone can tell me where the low speed needle is, and how to keep the engine running.
davidgp is offline
Old 09-13-2012, 11:28 PM
Foxy
Moderator
Foxy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Blur engine madness
Hi, moved your thread from the Exceed forum to Engines forum, I think you'll get better help faster in here.
Foxy is offline
Old 09-14-2012, 07:22 AM
purenitro33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure what style of carb you have but the one below is how most slide carbs are set up.
purenitro33 is offline
Old 09-14-2012, 09:30 AM
nitroexpress
nitroexpress's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rotary carb, not slide type.
I would guess the LSN is on the linkage side. The slotted screw in the middle.
http://www.shengines.com/spare%20par...ta/PT0701A.pdf
nitroexpress is offline
Old 09-18-2012, 01:05 PM
davidgp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, I found the low speed needle right where it should have been. It was so tight I thought it was only used th ehold on the throttle bracket. After setting it two turns out the motor ran a lot better, and after some tweaking to eliminate a little stall on tip in ran very well, right up to the point the pull start broke.
davidgp is offline
Reply
Display Modes
