Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Best clutch shoe springs for take off??
Reply
Old 10-31-2012, 10:32 AM
Thunderbird93
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best clutch shoe springs for take off??
What clutch shoe springs gives the best off-the-line take-off 1.1 or .9?
Thunderbird93 is offline
Old 10-31-2012, 11:06 AM
nitroexpress
nitroexpress's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best clutch shoe springs for take off??
Quote:
ORIGINAL: Thunderbird93
What size engine?
nitroexpress is offline
Old 11-01-2012, 01:36 AM
Anthoop
Anthoop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The thicker spring will mean the engine will be at a higher rpm when the clutch engages, higher rpm will produce more power.
This does not mean that the thicker spring will produce the best take off...that is down to how much traction you have...for example on a loose surface the thinner springs may give less wheelspin off the line.
Also worth mentioning that the weight of the shoe will affect engagement rpm, so you may be using aluminium shoes with a 1.0mm spring that engage at the point you need but if you changed to using composite shoes then you may need to use a thinner spring to have the same engagement point.
Anthoop is offline
Old 11-01-2012, 04:24 AM
Thunderbird93
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a few engines I'll be looking to put springs in. The first one is an LRP .28 with aluminum shoes in my 14 lb. XTM MMT. The next one will probably be an XTM 457 in my Revo...I'm looking for the best takeoff for grass and street. Thanks.
Old 11-01-2012, 09:02 AM
Ttowntoolman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Anthoop
Perfect explanation! +1
Ttowntoolman is offline
Old 11-02-2012, 03:48 AM
Anthoop
Anthoop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are working with a few engines/cars then why not buy a few different sets and do some experimentation, springs/shoes are fairly cheap.
Anthoop is offline
Old 11-02-2012, 04:22 AM
Thunderbird93
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthoop I thought about doing that. I've always used 1.1 and I just ordered some. 9 springs.
Reply
Display Modes
