If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
Thread: LRP 28
  1. #1
    PrjctStrtFrce's Avatar
    Join Date
    Aug 2005
    Bartlett, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    LRP 28
    I have a newer LRP28 that has the XTEC case, and an older LRP28 VTEC case. Are there any differences between the cases or is it just the different stamp on the case??
    Also, I purchased a motor parts lot recently and the LRP28 was modded by TNT MODS; only that the crankshaft was modded. I assume that just using the modded shaft in an otherwise non-modded LRP28 would be okay?? What does a modded crankshaft provide? I know that a modded sleeve has better intake and exhaust flow.
    Keep your RCs, get rid of the wife. -bigwaltc-
    SFGP,HPIX4.6,XL,RS4 3,MERV,Kyosho IGT2RS, Redcat Rampage MT V3
  2. #2
    Anthoop's Avatar
    Join Date
    Feb 2007
    Somerset, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: LRP 28
    I can not answer the different case question but I am interested to know, I have a Nosram 28 with VTEC on the side. (I expect HerrSavage will know the answer).
    Using the modded crank in another engine will be fine, as for benefits of the modded crank, that will depend on what has been done.
    When I die, I want to go in my sleep like my grandfather,not screaming
    like the passengers in his car at the time.
  3. #3
    Join Date
    Sep 2005
    Irgendwo, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: LRP 28
    I don't know anything about mods of course.. But afaik, the only difference between VTEC and XTEC is the first letter. The reason it changed was a legal/trademark/whatever issue with Honda.. I.e. no difference.. The VTEC's are just older, from before the change was forced through.
    I don't know that %100 btw. Just seem to recall reading it somewhere..
    Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
  4. #4
    Join Date
    Aug 2005
    Bartlett, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: LRP 28
    Yeah, I laughed when I saw the used motor that had VTEC on it because it brought back memories of when Honda was in the middle of that "legal" matter.
    The crank was just bored/polished on the intake and back area, where the pin is for the back-plate.
    I have yet to disassemble the XTEC motor so that I can compare them side by side. I wasn't sure if one or the other may have had better bearings, stronger material, etc.
    Oddly enough, I purchased this motor lot so that I could get the carb pinch bolt from the LRP28, and I ended up getting quite a few Mach427 and Mach454 pieces in great shape as well.
  5. #5
    1QwkSport2.5r's Avatar
    Join Date
    Oct 2006
    Cottage Grove, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: LRP 28
    If you have a vernier caliper, just measure a few things to compare. ie: distance from the cylinder deck (top of crankcase with head removed) to the top of the various ports in the crankcase, etc. You could degree the engine as well, but that is a little more involved. Degreeing would only show the timing of when the ports open and close, and duration. This might be different, but I doubt it.
    GlowHead Brotherhood #3
    Real engines use glow plugs.
    R.i.P Jacob Wetterling #11 10/22/1989
  6. #6
    Join Date
    Aug 2011
    west yarmouth, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: LRP 28
    the cases are the same.a modded crank if done right provides more fuel to the sleve ports however if the sleve is not moded it  wont give u more horsepower they are done together.port and polish the sleve and crank.some modders do the head button to
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
