replacement engine
replacement engine
I have a RS4 RTR 3EVO, it came stock with an HPI T-15 engine. It's always been a good engine but I would like a faster engine, so could you guys recommend a replacement drop-in engine for my RS4 RTR 3Evo?
Paul
Paul
RE: replacement engine
Because I think OS are grossly overpriced namely for the lack of quality, I'd suggest either an SH/Dynamite/Mach/XTM/etc. engine for the budget minded, and for a few more $$$, go Picco or Novarossi. Thunder Tiger makes good running engines as well, along the same budget lines as the SH/Dynamite/etc. engines although quality-wise, I think the TT has the SH line beat by a little bit. Some TT engines outpower OS engines even.
Oh.. and sometimes OS' Nickel plated liners peel. Then you have an expensive paperweight.
ORIGINAL: 1QwkSport2.5r
ORIGINAL: Anthoop
He needs a side exhaust...and the 18CV is ABC....but other than that it is all down to budget.
Haven't seen an actual chrome plated OS liner. All I've seen are all ABL/ABN. OS has gotten cheap in quality and high in price. Kinda shoddy IMHO.
CA
And any of the brands of engines I listed can be had with side exhaust.
ORIGINAL: Anthoop
ORIGINAL: Anthoop
Depends how much you are spending...but I guess a OS 18 CV will drop straight in.
ORIGINAL: nitroexpress
OS Engine 21913300 Cylinder & Piston Assembly 21TM
[img][/img]
ORIGINAL: Anthoop
[img][/img]
I am impressed. Must be just some of the car engines that get the real ABC piston and liners. I still wouldn't buy one though. $82+ for a 18CV piston and liner is ridiculous, the 21TM at $98 is even more ridiculous. The brass must be gold plated or something.. Crazy.
Not many car engines (cheap or expensive) are worth repairing if it needs a sleeve because you are going to put in a rod for peace of mind..and the bearings....no point.
ORIGINAL: Anthoop
Take a look at the prices of Nova pistons/sleeves. [:-]
I'm a believer in "if it ain't broke, don't fix it"; If the conrod and bearings are still good, and a liner set can be had cheaply enough, I'd just resleeve the engine and go beat on it for another 10 gallons.
But thats just my opinion.
I am not trying to put OS on a pedestal...but for the car in question the .18CV is by all accounts a very good choice. I presume you have had some bad experience with OS?
I love NovaRossi engines (so I am not trying to knock them), but which engine was it you were recommending for this application?
Bearing in mind just now you thought that all OS engines were ABL/ABN, I find it hard to understand how you know the quality and how long it will last?
Pistons and sleeves are not cheap and in general are not worth replacing.
ORIGINAL: Anthoop
Piston and liner sets are expensive, but if the engine is treated properly, the P/L set should outlast the bearings.
edit: If I had the equipment and skill, (barring in mind I ever wear out an ABC P/L) I'd convert the P/L over to a hardened/nitrided steel liner and hand lapped meehanite piston. This is how our engines originated back in the '20s and '30s.
Now that we've gotten so far off topic; lets give the topic back to the OP.
