4-shoe clutch
4-shoe clutch
If 3-shoesare better than 2....are 4-shoes better than3?
I'm looking to upgrade my clutch on my D8T and considering M2C6075. Is there any down-side to going with 4 shoes?
Thanks!
RE: 4-shoe clutch
I have never tried a 4 shoe setup...but here are my two pennys:-
If you are not having problems (now ) with your 3 shoe then why do you need to change?
I read most of your posts (if not all) here, so I know you do some racing but so far it is your control that is the limiter to performance....not the clutch.
I see a lot of adjustment potential with the setup you mentioned, which is fantastic if you are able to lap consistently and are able to distinguish the differences between the changes you make.
I also noticed your son looking for an upgrade for his 2 shoe...maybe there is a little plan there......
RE: 4-shoe clutch
Thanks for the reply.-MNo issue with the clutch but would like to upgrade if possible. I DO prefer aluminum over composite, so that much I know I'll enjoy. The intent however is to understand a four shoe would offer....heck, why not a five shoe. ;-)
Regarding Andrew going from 2 to 3.....I can honestly say the single bigget difference I've seen on a specific upgrade to a car was upgrading my Losi 810 to a 3-shoe M2C setup. Anyway, I personally think his Losi has a 3-shoe, but he'll need to take it apart to see for himself. ;-)
MI
RE: 4-shoe clutch
IMO The benifit of the four shoe clutch system is you are able to make kind of a two stage engagement with two different spring rates directly across from one another, one pair will come in sooner than the other for planting power to the wheels more evenly, some people like it some like other designs....test and tune will tell you what will suit your driving style.
RE: 4-shoe clutch
M2C makes an amazing clutch...........it would be a great upgrade...you will notice your engine will put its power down more effectively as opposed to the stock clutch....you will notice a big boost in low end snap
RE: 4-shoe clutch
Yea, I have an M2C on by 810and it RIPS!
I'm finding clutch-tuning to be my favorite part of tuning so far. I like to try a variety of set-ups, and that M2C 4-shoe has it. I'll upgrade once the stock starts to wear (and I like to keep clutch parts like new so we'll see how tough D8T stock clutches are.) So far I'm getting decent snap, but want to try some 1.1's for higher RMPs to garner that snap.
On a side note: M2C is a great company. When I first ordered from them, I spoke with the owner, and he gave me a 15 minute dissertation on nitro clutches (and I tried to soak it all in). I had a shimming question once and he again was great on going into detail on clutch theory. ;-)
RE: 4-shoe clutch
ORIGINAL: JohnP2
1.1 springs are really only suitable for engines that lack bottom end power....when you high stall a decent engine it will just cause the clutch to overheat and usually will end up reducing the snap you initially installed the 1.1 to get..........A hot clutch is a bad clutch.....and 1.1 springs is the fastest way to add heat to a clutch.................
KY
RE: 4-shoe clutch
I have a question pertaining to the proper clutch to use. I have an Associated MGT monster truck and am a big basher. I looked up the M2C clutches and was wondering if the Universal 3-shoe clutch with springs and flywheel (M2C8050) would be a good replacement for the factory stock clutch setup. Also would you probably use the .9 or 1.0 springs with this also? Thanks for any advice.
RE: 4-shoe clutch
ORIGINAL: BChiz
