New, strange problem
OH
Having an issue with my LRP 28 spec 3. It is installed in my Savage X. After a recent run, it wouldnt start back up. Fuel would not make its way up the line and to the carb when priming. It would shoot right back down the line and into the tank after i primed it. Poured a little fuel into the carb, and it sizzles real bad, like th engine is too hot. It dosent run like its lean, and im getting temps of only 225-230 (verified by 2 different guns). Never did this before, and have never run into this problem on any other nitro i've had over the years. Thoughts?
OH
RE: New, strange problem
How in the world can the carb get overheated when the plug is only at 230ish? Never had this problem before too, weird. I thought vapor lock meant the engine was flooded...? Pulls just fine, am i missing something.
CA
ORIGINAL: ejc34710
OH
You desribed the problem perfect. Weird, must have just been running it a little more lean than normal. Thanks for the info, much appreciated. I'll figure something out. Wish these darn LRPs didnt load up so much on the low end... Thanx again.
