Engines "sqiurting" fuel from under head button
NY
I have two older engines that within the last 3 years have had the sleeve re-pinched. A Fantom FR .27 and a Picco .26 "Outlaw". I just recently started running them. They run absolutely amazing except for when I first start them they both noticeably squirt fuel from what seems like under the head button. And yes the head screws are all tight and with loctite. It doesn't affect how they run but I'm just curious as to why this is happening. Thanks.
Pinching may have distorted the top flange of the cylinder. A few careful swipes on a plate of glass with 400 sandpaper may flatten this out, and after that, a careful lapping of the head to give a nice surface. A good cleaning would be in order after these operations.
And when it runs? If the combustion chamber isn't sealing properly it shouldn't run "amazingly". And if it does you should hear hissing or small pops coming from the area as well as smoke and fuel leaking out of there.
I'm guessing your carb is leaking somewhere and it's squirting fuel under the head button making it seem like it's the head button leaking.
Does it hold compression when turning it over by hand? If it hisses out in a few seconds, it is getting through somewhere, plug seal, head, or piston/cyl. It will still run fine, just a bit different needle setting, but will be down somewhat on power, maybe not noticeable.
