Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
ofna force .28 head shims
Reply
Old 03-19-2017, 08:27 PM
rob28x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ofna force .28 head shims
how many head shims should this engine have 2 or 4 the manual diagram shows 2 it had 4 when i took it apart i got this engine in a large lot of R/C parts and several buggies i found lots of things not put together correctly on 2 Traxxas Revos so i am wondering if the head shims maybe wrong also
i have resealed this motor cleaned and lubed it factory carb settings hsn 3 turns lsn flush it will start but will not run for long or die when i remove the glow starter {rich condition?} i can lean the hsn about 1 turn and it will no longer start also i can lean the lsn about 1 1/2 turns and it will no longer start i am now wondering if it has double the head shims if it is lost to much compression i will try and remove 2 and see what happens
just looking for some insight into this
rob28x is offline
Old 03-20-2017, 05:54 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shimming the head lowers the compression. Measure the head clearance and shim the head so you have .4mm head spacing (about .015"). Most often this will require 1-2 shims of .1mm-.2mm each. You should measure first and shim last. Too much head spacing will leave power on the table unless you use gobs of nitro in the fuel.
1QwkSport2.5r is offline
Contact Us Archive Advertising Cookie Policy
