How often do Glow Plugs go bad??
RE: How often do Glow Plugs go bad??
depends on several things.. if your popping plugs you may be running too hot, wrong plug, worn rod or main bearing, bad fuel,, many things .. For a start use some good fuel.. see how you go from there
www.cooperfuels.com
www.cooperfuels.com
Like what above said. MANY factors come into play when glow plugs die. If you have already replaced 2 so far, that is quite normal during the break-in time for an engine. Almost everyone has gone through a few plugs during break-in. Once the engine is tuned right (not running too hot or lean), and have good fresh fuel running through your engine, then the glow plugs should last you a very long time. I havnt had to replace mine for quite some time now (around 3-4 months now).
