Need Help here. Car doesn't start.
Hello guys.
I Bought one Nitro Evader BX 3 weeks ago.
Last sunday I was running my buggy fine and sundly stoped to run the engine.
I've cleaned carburator, engine and glow. but nothing happen now. The engine not turns
Only 3 weeks with a RC and this thing happen SUX.
I Live in Brazil. Can someone help me?
My Feedback: (33)
RE: Need Help here. Car doesn't start.
guessing you seized the engine , but it looks likethe piston moved a little from the pics . Try to manually turn it over at the fly wheel .
1 Post
Yeah, if the con-rod has snapped the piston would still be able to move. Try moving the piston through a complete stroke and have a look at the con-rod, 1-way and crankshaft by removing the backplate. [sm=thumbup.gif]
NEW PICTURES
Remember this is a Duratrax and I run only for 3 weekends or 8 fuel tanks
My Feedback: (33)
Dang ! Did you forget the air filter ? That sleeve looks pretty scratched up . That will for sure cause problems and loose compression . Time for a new piston , sleeve , and rod . Make sure to clean that engine out good and check the bearings to make sure none of the dirt got into them .
I Used the air filter, but without air oil.
Very strange
My car only turns with accelerator pushed to the end. If I release a little the engine stops.
Very strange
If the connecting rod has snapped can you replace just that or is a complete rebuild required? I think i have the same problem. (With out the scratches on the sleeve tho.)
1 Post
I'd suggest you just buy a new engine - i don't think it is worth replacing the piston, sleeve and con-rod in a budget engine. You could probably pick up a decent OS for just a tad more $ than the price of the replacement parts.
My Feedback: (33)
ORIGINAL: shamelessbill
1 Post
ORIGINAL: Dawman
If the rod is broken it more than likely did some damage to the piston skirt .
VA
ORIGINAL: evdutcos
Very strange
Very strange
You screwed up by not using air filter oil. Expensive lesson learned.
