RC Car Actions "How to port a Nitro Engine"
#376
RE: RC Car Actions "How to port a Nitro Engine"
Hilifemt,good idea on praticing on an old sleeve first.
As JB said the angle is not quite right....also try not to make the cuts too deep as this will reduce flow speed.See the dark lines on the sleeve...this is a good guide for the required angle.
I've (crudely) edited your pics to try and help.
#377
ORIGINAL: Anthoop
Glad I had an old sleeve. It makes for good practice without any worries. Hope I get it right on my good sleeve now
thanks again Anthoop
#378
I cut my good sleeve today. I kept it real basic since it was my first time. Got the fang angle better than my practice sleeve and didnt cut as deep. and polished it up. Thanks for the tips guys. Im excited for this nasty blizzard to pass so I can test it out!
#379
WA
I have some extra parts, and an engine laying around (the undamaged sleeve to an Axial .28RR that I will use for practice, and a well used SuperTiger .27 pullstart from a Duratrax Raze that still runs), so I think I will try this.
Who knows, maybe it breathe some new life into that little engine. hehe
#380
ORIGINAL: hilifemt
#381
Dont give up, keep that sleeve and keep on practicing on it. It will be mangled to high h3ll, but your steady hands will come. Cutting a sleeve in 20min will not yield good results (unless you are very very proficient with the Dremel). For me, working on a single sleeve can be a whole afternoon affair. Just be patient and wok on controlling the tool from jumping and chattering. Soon, you will become proficient enough to cut curves and even wright with the Dremel with some ease.
#383
Looks nice supertib, on the first crank in the pictures, did you grind the crank pin or is that the way is comes stock?
#384
FL
Hey I would like to see how those cranks look......But your pictures are not showing up...Can you repost by chance?
K223
K223
#385
ORIGINAL: K223
K223
K223
they are on photobucket...your likely lacking a necessary plug in to view photobucket images..
#387
IN
Pictures can only teach/show you so much... Theres ALOT more to know when trying to make power with these engines then just the flow mods that u can see in pics. Timing plays a HUGE role... And you have to know when and where to alter timing by looking at all the engines timings... then seeing where the engines timing needs to be altered. You cant just go cranking the timing to what ever you want of course Knowing when and where and to what degree to alter timing to is where the real knowledge of engine modification comes into play.
I had an old modified sleeve laying around so I popped a couple pics for you guys to check out. Of course in these pics you cant see where timing has been altered.
#388
Adam, I can see where you could do more to the out side of that sleeve, but like you said its an old sleeve, so I guess it don't matter.
is all the done with diamond files?
#389
FL
True pictures can only show and guide you so much and that is not the knowledge one needs to by far only arm theselves with. Not that these little two strokes work quite the same way as a gas automobile engine, I have a bit of knowledge in regards here and I know how complex this whole game is on modifying performance. The difference between hi performance modifications and rebuilding an engine to stock specifications are like day and night.
Strage I cannot see any of these pics either....I can see some by others and in different threads. Maybe I do need some type of plugin???
Where can I learn more about the engine timing in regards to these motors, does anyone have any links that I can read up about? I would guess the only timing we are working with here is in relation to crank posistion and TDC through compression to the power to the exhaust BDC to the intake strokes....Which are only comprised of two. Just curious to where the adjustablility is in timing, or we just talking about modifying certain events and the flow characteristics at that point?
Being these motors work on such simple and limited operations.....It can be easy to gain some power, but then again do one small thing wrong and you really have a problem as well.
Looking forward to picking up some good information here.
K223
K223
#390
how do figure out if you should do 3 turbo cuts like
or if you should do just 2 like this one?
hope you don't mind that I copied your pictures.
#391
WI
hey guys, i like the pics. i to am in a deep freeze here in wis. so i've been doing some modds on some engines. i have some question 4 u guys. when u put the fanges on the sleeves, y don't u use a grinding stone in stead of a cutter, they don't jump so much. also have u ran your motor with the modded con rods and how do they run. do u get more rpm's out of these motors after your done? i find that not to many "pro's" like to let anyone in on their secrets for porting and what works best. i have an os rg that i would like to get alittle more rpm's out of so if u guys know any secrets that u don't mind sharing, that would be great. also any tips 4 a sh .28 would be great.
#392
ORIGINAL: dayglo
1.)When u put the fanges on the sleeves, y don't u use a grinding stone in stead of a cutter, they don't jump so much.
2.)also have u ran your motor with the modded con rods how do they run. do u get more rpm's out of these motors after your done?
3.)i find that not to many "pro's" like to let anyone in on their secrets for porting and what works best.
1.) the grinding stone will clog up with the soft brass, (on soft metals you want something with some teeth to cut into the metal) and you don't grind the fangs, you cut the fangs so you use a cutter to cut
2.) I do not mod the conrod.
3.) the pro modders will not give out there secrets of modding, thats there business, it would be like a walmart telling K-mart there secrets on how to sell stuff. so a pro modder will not tell some one there secrets. thats how they make there money. go up to microsoft and ask them how to make window XP or vista and see if they will tell. (I've tried, it didnt work for me)
but theres others that will help. I would but I don't know enough to really help you, you seem like you know how to do basic sleeve mods, and that all I know at the moment.
#393
WI
so what do u consider it when u put the scoops on it? do u polish it as well? what about running your engines. about the tips from pros, when we try this stuff, i don't think i'm going to steal their busness, just would like some simple tips on how to make more rpm. this might be the best kept secret since????????????? well i don't know what
#395
ORIGINAL: dayglo
the turbo (I'm guessing thats what you're calling scoops) cuts in the crank, are there to mainly mix the fuel and air.
I'm not sure what you mean by "what about running your engines" there might some pro's that will help, but the best way is to find one that don't mind helping, there's people on this forum that know alot about modding and timing an engine, but some of them will not take you seriously till you know some stuff already.
I'll PM you some of the links I was given.
to get more top end out of your engine, would be to mod the exhaust timing, I would like to be able to tell you, go to this degree, but I can't no one can unless they have modded that engine before, or have atleast timed it.
how much do you even know about timing? do you know how to degree an engine?
#396
IN
ORIGINAL: JB COMP
And on my sleeve pics there is no need to take anymore material out of it then there already is. Taking away too much material can actually give you negative results.
#397
FL
Looks like nice looking work. Since this sleeve probably belonged to a high performance turbo racing motor, I would be curious to see what the stock sleeve looked like in comparison to your now modded sleeve. I just think it would help to showcase your work, not to mention give some the incentive to send you a motor to do.
K223
K223
#398
JB those cuts are there on those crankshafts stock... Tib smoothed and reshaped some for them to flow better.
how do you know when you take to much off? and what would happen if you did?
#399
IN
That sleeve that I posted doesnt have any fuel channels when stock. Those were all cuts/modifications I performed on the sleeve. I dont have any stock 821 sleeve's laying around or I would post one up.
#400
WI
jb, i mean how does the motor run when your done with it? u mainly just do the fangs on the sleeves? or do u mess with timimg yet? and yes i know i need a degree wheel to set different degrees but even if i got one no one wants to give measurement anyway. i have read though this tread and many others to find out all that is out there so any help is very apperated.
