Toki engines, any good?
RE: Toki engines, any good?
Im not certain, but I think the Toki factory produced my RD Logics Team Infinity .12ci 512 Katana. That engines was my very first nitro engine; it kasted me about 7 or 8 gallons. I am guessing because I broke it in according to the manual (which said to idle it on blocks!!!!) and because I did not take as good as care as I should have.
LOL, stupid speeding tickets!
I am thinking the Toki engine should be of reputable design and production quality. When you get it, break it in using the heat cycling method. Then let us know how it hilds up for you.
toki engines are junk. Orion, peak and fantom used to use them as their engine manufacturer. they had nothing but problems and engines that lasted no longer than 2-5 gallons. its also why they no longer sell their toki made engines.
ORIGINAL: Kemo
The consumers insistance of running them cooler is why these engines lasted only a couple gallons, not the design!!!!!
In their origonal form, they were a dozen gallon engine, when properly borken in and run.
My Feedback: (9)
CT
The only toki based engine I've ever owned is now a paper weight after exactly a 1/2 gallon of fuel. The worst engines to ever hit the market IMO.
FL
I have a vertex and it's been pretty good, I ported it last night and was trying to find a tune today. If toki makes the vertex then its definitely worth 65 bucks.
FL
I got the engine broken in and it hauls, it is so smooth and quiet compared to the rtr engines. I took it apart and the scrank shaft weight is already notched. It ran during break in as if it was already broken in, I did a couple 1/2 throttle passes and it wizzed by. I'll port it this weekend and see how it does then, I think awesome. Temps were very low and required lots of leaning to break 200, idles great, low end, mid ant top end. 0 complaints here.
Toki make according to what market it wants to sell too.
If its cheap then its not the best quality but then again what do you expect for the price.
Id buy one or two for the price to use for messing around and maybe to mod to see what happens when you mod engines etc...
The make the Orion CRF range of engines and the quality is exceptional.
The infinity range of engines are a budget range good for the basher with limited $$$
