i should have listened
FL
a bunch of you tried to tell not to go with a wasp 28,but did i listen,,,NO!!!!was pretty good for about a half gallon or so,now,cuts off at about 240 degrees,wont start till completely cool,pinch is still goood and tight,when it runs its decent,but i should have listened,now i be lookin at a spec 3 or an sts for the savage
RE: i should have listened
remember you can have pinch, but have no compression, warped sleeve? or score marks in the sleeve should be what your looking for, if theres either then the engine is buggered, if the p/s are in good condition its probably just a tuning issue like TWT said, symptoms sound like a classic case of loss of compression though.
FL
thats what i am thinking as well,ran it agin last night,fired right up,ran alittle rich(engine was still cool)got to 210-220,started running good,240 shuts down,plugs good,pulled it,its getting fuel,nothing,even drop a couple of drops of fuel down the plug hole,wouldnt fire,survey says.............................................. ........toasted wasp
MA
I also had the wasp .28 and mine would do the same thing. It would die right after it got hot and then would not restart. What a waste of money.
