stock vs custom mod?
just wondering at the pointy end of the buggy and truggy class's if people are running the stock out of the box top end engines in racing or taking thos engines and getting them modd'd . the reason im asking is because i was reading about the axe rossi r25 here in australia that people are racing with straight out of the box and winning at championship level?
are engines of this caliber that good out of the box? cheers
FL
RE: stock vs custom mod?
oh ok i see now abit of a noob , iv come from pro go-kart racing , were you would never dear to run an engine straight out of the box with out spending a lot of time porting , changing timing , barrel hights and so on and so on . the engine would just not be quick enufffffff
FL
ORIGINAL: uhoo_01
Yes many engines come race ready, most high dollar engines are engineered to the max, modding can help, but most of these motors have so much power its nearly unusable.
Good drivers don't need a modded motor to be good,
But equipment is more then 10%, its kind of a mix of equipment and setup make up alot of it.
Equipment - 20
Setup - 30
Driver - 50
That's how I see it lately, a bad setup can make a good driver look worse then he is.
Driver
ORIGINAL: dkastil
[sm=50_50.gif] cmon!
ORIGINAL: JB COMP
I port and some times changed the timing on most of my engines. (Just because I can[>:])
That's what I do, I've modded one of my engines timing and all, and ported a few others. I don't race, so I mod my engine just because I can and I want to. What more of a reason do I need?
ORIGINAL: slayerphonics
To answer your question,
ORIGINAL: uhoo_01
IN
Theres more to modifying an engine then to just get more power. A properly race modified engine will have the powerband smoothed out so you can use the extra power of the engine. A LOT of people that race run modified engines for a reasons other then just PEAK power.....
ORIGINAL: Colt4g63
+1 ^^
More useable power when modified the right way
GA
One of the benefits of mod engines if done properly you get better fuel economy and as any racer knows if you have to pit less often better chance of placing well.
ORIGINAL: JB COMP
What?
ORIGINAL: dkastil
ORIGINAL: JB COMP
ORIGINAL: dkastil
what ? i mod engines just because i can ,sorry but that just sounds snotty .
ORIGINAL: JB COMP
What?
ORIGINAL: dkastil
ORIGINAL: JB COMP
