Bent Shim
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
Bent Shim
I've got a new and modded Jammin JPX 21. Ordered a shim for it from Amain but they shipped it with no cardboard protector. So the shim has been slightly bent and tweaked. I'll be running 25% Byron's gen 2 through it. I also need to get an exhaust gasket for it, so my questions:
a) Should i shim it
b) Is it OK to use the shim if its a bit tweaked
c) Any idea which silicone exhaust gasket I need to get (I've only had OS engines before and they came with gaskets)? I can see that there's no groove on the exhaust port of the Jammin like there is on the OS, so those gaskets aren't interchangeable.
As always, thanks for sharing your knowledge and experience.
**Addition: Just took the cooling head off the JPX 21 and realized unlike the OS engines, there is a seperate glow plug seat that isn't attached to the cooling head. How do i remove that to add the shim?
a) Should i shim it
OK
RE: Bent Shim
to my understanding, shims go through some compression force other than that they are just spacers to keep things apart and moving. If you can get the shim bent backward to as close to its original shape as you possibly can, then it shouldn't make that much of a difference. Worst case - it will cost you a bearing or two should they cease.
RE: Bent Shim
ORIGINAL: rageworks
You will need the exhaust seal made for the
Picco/Jammin engines. It is Ofna part #51915.
FL
RE: Bent Shim
once you tighten the head down any "tweak" to the shim will dissapear. more shims = less power, lower mileage, longer life. less shims = more power, better mileage, shorter life.
