How to find timing on an engine
CA
I know some guy skeep secrets () but how does one find the timing and then go on to moddify it on your engine [8D] In this case I have a Mach 427 and an LRP 28 that I want to change the timing on but I am not sure how to go about doing that. Anyone willing to share, last thing I want to do is take a nice engien and trash it
NY
RE: How to find timing on an engine
ORIGINAL: calvino
Come on guys chime in and lets talk about this.
Jim
well, if the engine you already have is full of torque and power, then this type of mod is probably not a good idea. as for the lower end engines, timing changes( i say changes because once you've done this it cannot be reversed ) are done by altering the exhaust port and the intake window on the crank shaft. you will need a dremel tool and some carbide and high speed steel cutting bits. i will post a couple links on porting. if you don't have the experience with dremel precise cutting it is best left to a mod shop.
http://www.rctech.net/forum/nitro-ro...ro-engine.html
this is a port and polish how to.
http://slappytees.com/images/savage/...I%20Nitro1.pdf
this one is how to make the HPI S25 a real performer. the last number after nitro in the link, change it to 2, 3, or 4 to veiw all pages.
ORIGINAL: calvino
Why do you want to change the timingm what performance aspect are you wanting to gain? Torque, RPM's...?
CA
Generally "both" but maybe more RPM's from the engine From what I remember the LRP had good torque but I found I wanted a few more revs if possible
ORIGINAL: VooDooModified
ORIGINAL: calvino
However, the lrp .28 is quite aggressivly timed from the factory. Durations: Crank 214 degrees,(opens 22 degrees ABDC and closes56 degrees ATDC) intake 130 degrees and exhaust 174 degrees.
Flow mods does little to the engines power output
The power is in the timing...
IN
You can use something as simple as a timing wheel to measure port timing or calipers, depth gauges etc to measure port height and use a timing software to put the #s in and keep notes etc.
As far as knowing where to move and what ports to move the timing on is the trick... This takes many years of experience and R&D to do it properly and get the end goal that you want out of the engine.
CA
ORIGINAL: Colt4g63
The easiest way to determine the timing profile is to get a degree wheel and measure each specific port duration.
Or just like what Adam said, you can measure how far down the piston is with a caliper and then calculate the duration from that height measurement.
The software he mentioned is really nice because it does all the calculations for you. This is great because it totally eliminates all the trig work that you would otherwise have to do to calculate the sleeve port durations
These are for the sleeve ports now, which are relatively straight forward.
The induction port on the crank shaft is not as easy; it does take a bit more measuring and calculating before you arrive at the duration for this specific port.
I wrote this thread several years back tackling this port duration calculation and also calculating how far you need to cut to open up this port.
http://www.rcuniverse.com/forum/m_59..._1/key_/tm.htm
Making sense of when this induction port opens in relation to the sleeve ports requires plotting your port durations on a timing profile map.
And this is where the software that Adam describes makes it beautiful; provided your measurements are accurate, the software will do this duration plotting for you and give you a concise timing profile map.
And yes, as far as modding, it does take considerable experience to know how to make these port durations work in unison to give you an effective power increase.
ORIGINAL: bigdogkanicsar
Thats not true, it depend on the existing timing, compression and design. The power output also have nothing to do with how far you can go, no offense...
ABmods squeezed 1/2hp more out of an OS.28XZ as a perfect example. (1.97hp stock, 2.51hp drag mod)
For the timing, the degree wheel is a good way to understand how it work, but the software is a lot easier and precise lol
Like Adam said, if you want to learn, you will have to spend time and money to test , test and test.
Took me a while to learn, and some $$, and some help from a good friend who is pretty good i have to say...
If you are really looking to learn it, take your time, do small change and test, 0.2mm can do wonder or disaster.
Good luck!
ORIGINAL: Over_revO
Good luck!
Good luck!
Damn I didn't know there was a nitro car engine capable of 3hp and 45,000 in the same package.. Things sure have changed in the last year [&:]
ORIGINAL: rcnitrohead
check it out
http://www3.towerhobbies.com/cgi-bin...?&I=LXXYF6&P=0
well my mistake 2.7hp with practical 45,000rpm or that's what they claim
check it out
check it out
The bold is where you fail. I'd like to claim my Picco .28 puts out 4.5hp at 50k RPM.
check it out
check it out
What does a video prove? The same thing as you claiming that an RB Supercharger works right? You like talking but can't back **** up with facts.. The average joe R/C guy knows that numbers advertised for nitro engines are the same numbers that are pulled out of someone's ass. Cocky? Really? My advice for that guy was spot on IMO, I gave him exactly what he needed. If anyone needs growing up, its you man.. Go strap on your RB supercharger and make some boost while your at it...
see ,you're funny too. i give you the link to where o.s. runs the info on the engine and you still waana be 10ft and bullet proof( which is pretty easy to do over the net) but you are the uneducated one that can't read what people write. I SAID THEY CLAIM. not i claim. go back to school. maybe you and that dude ought to shack up together. maybe O.S. does embelish a little along with every other manufacturer. but at least i posted the stats according to O.S. and tower. where are your FACTS homey?
just so we are clear i never said the supercharger was a giant boost in power, i said it makes up the difference for it's weight + a little more. and that's from the one i had. i can't speak for other people. you just like the other guy need to learn to read.
I read what you wrote accurately.. You said a supercharger WILL produce gains.. Previous discussions (and I could dig through about a hundred threads) which included those that are extremely knowledgeable on the subject deemed it impossible to work on surface specific nitro engines.
As for the O.S., I did read accurately as well, and here is what I go by:
Adam's dyno sheets..
Xtreme RC's engine database
Which show extremely different results relative to manufacturer claims.
IN
XRC and I use the same dyno. The X-Dyno which has become standard in the industry of HP ratings for engines. Its in SAE correction factor.. Has a weather station etc. Its the REAL DEAL.
ORIGINAL: Colt4g63
^ Hey, just doing the exact same thing you did in the other thread... LOL
Tact or not, I'm here with facts.. You can go ahead and keep whining about etiquette. No life right? So one can assume there everyone on RCU is a loser with no life right? Cause this thread and 2 on the HPI forums are the only ones I've participated in some time.. If you think I'm trying to act like a tough guy, you must be more retarded than I thought. I know exactly how and when to act in a certain demeanor, I've done more for my community as well as the local R/C community here than you could ever accomplish in your mom's basement. This is done, all the info was clarified, we've had our pissing match, the popcorn is eaten.. Good day sir.
the only losers on here are the one's that have no clue what a GOOD demeanor is.
I know when something is finished.. You apparently dont. Sad to see that if you really aren't 12 years old, you continue to argue like a child.. And if you call being a hospital volunteer and an auxiliary police officer giving alcohol to bums, then you have your priorities ****ed up. Good to know that our hobby is junk to you, I don't even know why your here. Good day.
Go ahead and have the last word, I could care less.
I also apologize to calvino for letting this turn into a pissing match, sorry for adding fuel to the fire man.
