Alpha parts in Nova p5x???
MB, CANADA
Hi guys,
I need to rebuild my Novarossi P5X, namely a new piston and sleeve.... i see they are about 150.00 US, and am wondering if i can run the ALPHA F850 piston and sleeve in the P5X.... as it is a 5 port sleeve, and the bore and stroke are the same.
the reason im asking is i can get the set for 75.00US....
let me know what you guys think?
ginnz.
Edit/Delete Message
ginnz.
Edit/Delete Message
RE: Alpha parts in Nova p5x???
It depends if the outer diameter of the sleeve is the same as the original one as well. Otherwise if the port timings are also the same, then yes. If not then I can help make them the same if possible.
