Modified Nitro Engines
Not sure what forum this goes in, but anyways. I was curious as to if you could use, say a .26 sleeve inside the S-25. But of course some minor mods would be necessary or atleast it seems it would too me.
anyway ever wondered this or tried it? |
RE: Modified Nitro Engines
Ive tried it on my buddys and it worked for a little and then he drove it off a ramp into the lake 2min after.
So im guessing if you put all the other parts neccessary also the it also might work ( MY HYPOTHOSIS ) |
ORIGINAL: crazypyro013 Not sure what forum this goes in, but anyways. I was curious as to if you could use, say a .26 sleeve inside the S-25. But of course some minor mods would be necessary or atleast it seems it would too me. anyway ever wondered this or tried it? |
The extra compression would proberably bend the con rod or crack the casing on the 25 engine
ORIGINAL: tegwin The extra compression would proberably bend the con rod or crack the casing on the 25 engine i figured that much... i was just a tid bit curious about doing that, i guess i'll try it on my old .15fe engine, i'll try swapping a .18 sleeve and piston and rod, and all that great stuff.... when its finished i shall report back about it |
Sounds kind of crazy but what the hell. Good luck crazy RC character!
modified? What the hell does that mean?
bump
