SH .28 engine?
Anyone know anything about the SH .28 engine?
I cant find anything remotely like a review on the net. Any info or opinions appreciated. |
RE: SH .28 engine?
I have one, well kinda
Hey I got one and loved it and dropped it in my Monster GT, MAJOR hole shot ability, easy to tune and started right up and held the tune as easy as stocker TT .21. I blew my piston and shaft and after further tips from you some pro's on a different forum I think it hydro-locked due to the drill start just pushing through it and it final blew the piston apart. Hobbypeople, the US rep, hooked me up. Sending them the engine as is( shipped out last friday) and for $50.00 I get a new motor Very happy.... Had already baught a Mach .26 prior to Hobbypeople stepping up so now I will have 2 Kick arse engines Liked my Sh .28 a lot |
RE: SH .28 engine?
Thats good news, thanks for that. Mine just arrived, gotta make it fit into a Cen funfactor now - this will be fun...
RE: SH .28 engine?
I helped a guy put (a 2nd ) one in a Savage...looks to me to be the same as the XTM 24.7 and Mach .26 except for slight differences in appearance and displacement. My bet is they're made in the same factory in China.
His first one crapped out right off the bat...piston/liner. He admitted that he might not have broken it in properly. I helped him break in the 2nd one, and that one's much better. It runs fairly strong, like a 24.7/Mach .26... I also commend Hobby People's service... |
RE: SH .28 engine?
i have 1 in my savage and i geared it 16, 49 and sometimes gear it 18, 49 but either way your putting out some big power and this engine would be even great for a buggy since the buggys so light for the motor and the motor can be gearded way high to make lots of speed and power, 18cb and stock gear is a great gear for this motor on buggys. i love it in my x-t and in my savage its all around awsome
RE: SH .28 engine?
thanks for the input guys.
what size tanks are u running and how long does the fuel last? i still only have a 75cc tank... |
RE: SH .28 engine?
Yea the motor originally comes in the xlb buggy 1/7th scale by xtm. it produces 3.5hp at 28,000 rpm, so they say. |
RE: SH .28 engine?
it does alright or close to it, oyu will NOT be dissapointed. ill guarentee it lol! trust me its a great performaning engine that pulls easy wheelies on the savage
RE: SH .28 engine?
also the rpm figure is low xtremerc cars dynod it and it revved to 38000.I had one but my piston and sleeve wore out after four gallons, it was used for winter indoor races and never really seen a good temp it was always running cold.
RE: SH .28 engine?
My savage does wheelies on 20% nitro fuel ,18/47 gearing and alloy hop ups but i have to replace the one way bearing often.SH.28 has great torque but from my experiance i'd look for something else.Going to sell my savage because i'm fed up changing the one way bearing on the SH.28 engine.The cost of replacing the engine outweighs the cost of buying a new truck.Wish i'd bought the wasp .28 that revs out at 42,000 instead of 28'000
RE: SH .28 engine?
ORIGINAL: poor judgement Anyone know anything about the SH .28 engine? I cant find anything remotely like a review on the net. Any info or opinions appreciated. Rich |
RE: SH .28 engine?
The SH.28 has alot of torque, and it's easy to over-rev it. Like when trying to do back flips, and winding it up trying to get a turn marshall's attention at a race. There's been a few people complaining about it's con-rod durability, and I think that's the problem.
RE: SH .28 engine?
many thanks for the warnings guys - i will keep a close eye on it.
RE: SH .28 engine?
Great engine! I'm very happy with the performance. But bad news on the one-way bearing. They don't last very long. They're are a lot of motors with internal one-way bearings. The oil from the fuel never affected them. Hobby People told me the fuel in the SH.28 crank case makes the one-way bearing slip. "BAD DESIGN". They should've put the bearing outside the block. Or design a better bearing!
RE: SH .28 engine?
Hi there, just bought one of these engines from ebay.
Sounds like some people have problems with the lower con rod bush. just wondering what the best way to check this bush is and does anybody know where i can get replacement parts for this engine should i have any problems. i am a UK member by the way. any suggesatioins greatly appreciated |
RE: SH .28 engine?
ORIGINAL: eadnoth My savage does wheelies on 20% nitro fuel ,18/47 gearing and alloy hop ups but i have to replace the one way bearing often.SH.28 has great torque but from my experiance i'd look for something else.Going to sell my savage because i'm fed up changing the one way bearing on the SH.28 engine.The cost of replacing the engine outweighs the cost of buying a new truck.Wish i'd bought the wasp .28 that revs out at 42,000 instead of 28'000 as for the OWB they dont fail if you know how to use them.... You likely use oily fuel and never flush your engine... If your OWB starts slipping flush your mill with some WD40 and the OWB will be like new.... All that is happebning is oil is coking on the OWB shaft making it slip.... Once agains a classic case of user error blaming a perfectly good engine. |
RE: SH .28 engine?
ORIGINAL: castandiello Great engine! I'm very happy with the performance. But bad news on the one-way bearing. They don't last very long. They're are a lot of motors with internal one-way bearings. The oil from the fuel never affected them. Hobby People told me the fuel in the SH.28 crank case makes the one-way bearing slip. "BAD DESIGN". They should've put the bearing outside the block. Or design a better bearing! As far as the SH engines chonically suffering from slipping one way bearings, I do not know but I am guessing it will not slip any more than a K4.6, Axial, D28M, D30M, etc. would under the same conditions. |
RE: SH .28 engine?
actualy to clean the OWB, remove the air filter... open the carb bore and squirt some WD-40 down the carb neck.... rotate the motor a few times, then let stand for 10 minutes.... Then the OWB will be like new.
I have been running these mills for years and years, and never had to buy a OWB ever..they will slip, but they just need to be cleaned. |
RE: SH .28 engine?
Yes I second that. Only I just remove the plug and then flood the engine with fuel, holding the car in an angle that ensures the fresh fuel to collect at the one way bearing, pull the rope to clear out the excess fuel, in with the plug and start her up. It only takes a minute, when external bearings slip it takes much longer to disassemble the pullstarter to clean the bearing.
RE: SH .28 engine?
i see nobody has mentioned which sh-28 they are talking about. hhhmmm interesting.
RE: SH .28 engine?
ORIGINAL: asmund Yes I second that. Only I just remove the plug and then flood the engine with fuel, holding the car in an angle that ensures the fresh fuel to collect at the one way bearing, pull the rope to clear out the excess fuel, in with the plug and start her up. It only takes a minute, when external bearings slip it takes much longer to disassemble the pullstarter to clean the bearing. I was about to go to my LHS to buy a new one...or might end me up buyin a starter box You saved me man !!!! monnette |
RE: SH .28 engine?
You`re welcome;)
RE: SH .28 engine?
ORIGINAL: monnette ORIGINAL: asmund Yes I second that. Only I just remove the plug and then flood the engine with fuel, holding the car in an angle that ensures the fresh fuel to collect at the one way bearing, pull the rope to clear out the excess fuel, in with the plug and start her up. It only takes a minute, when external bearings slip it takes much longer to disassemble the pullstarter to clean the bearing. I was about to go to my LHS to buy a new one...or might end me up buyin a starter box You saved me man !!!! monnette Hey but I while ago the OWB slippage returned back..Do I need to do the fuel flushing every time it slips? Or do you regularly do the fuel flushing everytime you want to start your engine? I just tried flushing it with WD-40 now and see if this works better than fuel. One more thing. Do you think regular use of ARO will cause more slippage I regularly use ARO whenever I will not use my buggy for more than 3-4days. Thanks guys monnette |
RE: SH .28 engine?
Usually everytime the engine gets cold the oil on the bearing thickens and then it has to be flushed again. I never use ARO, but all oils is a no-no on the oneway bearing and can cause it to slip. I usually do this flushing routine everytime I break out my car
RE: SH .28 engine?
Hi ! I need help . I'm a new in this hobby, and I have SH .28 engine whitout cluch...
I want to know which kind or which model I can buy, if you have kind or # model that's will help me very much. Excuse me english ;) Marc |
