If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 27
  1. #1
    Join Date
    May 2002
    Canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    30% Carden Extra 30 Plans
    Does anyone have a set of Carden 30% Extra 300 plans? I bought the aircraft used and needed the plans for some improvements.
    Uglystick
  2. #2
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 30% Carden Extra 30 Plans
    I have the same plane, and if anyone could help both of us out, much would be appreciated. I would like to have plans to be able to create spare parts if there were to be an accident.
  3. #3
    jw637362's Avatar
    Join Date
    Jan 2004
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello, this seems to be a major issue, I too am in need of plans for this aircraft. Carden Extra 300s. I have been in contact with Dennis at Carden Aircraft and he has stated that the designer is aproximatley a 2 hour drive from his home and he only makes this drive once every month or so. He is sending me the blueprints in the next couple of weeks when he makes the drive. I can make some oversized copies of the plans when they arrive and send them off to you if still needed.
    I have an immediate issue though if either one of you can help. I have gone in and rebuilt a crashed Carden Extra 300s, but am at a loss from the forward fuse sides. I do not know how they are built up where the wing recesses into the fuse. Can you take some pictures and post them or send me some. Trying to get this plane done for the Love air Big Bird Festival next month and this is the last portion of the repair.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	157644   Click image for larger version.
ID:	157645   Click image for larger version.
  4. #4
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JW,
    Give me a day and I will send you some nice pictures of that area.
    If you could send me a copy of the drawings when you get them that would be great. I am worried about being in the same boat you are. Will the plans detail out the TOC mod for this plane? If you can get that as well, that would be great.
    Shoot me an email b_hargis@hotmail.removethisforspampurposes.com and we can work out the details.
    On a unrelated note, mine has a brison 4.2 for power. Do you guys think that is enough for decent 3d with this 20+ lb plane?
    Do either of you know where I can get a carbon fiber wing tube? I think it would reduce the weight some, Im not so sure though about the landing gear if there is a lot to gain there.
    Again, shoot me an email JW. Send me an account to send the pictures to and let me know the file limit.
  5. #5
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh yea, could either of you give me a recomendation for servos for the plane (what size, etc)
    Mine currently has holes for the rudder servos to be in the tail, but either of you do a pull pull?
  6. #6
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I need copies of the plans as well.
    I want to remove my canopy and redo the top of the plane.
    Plans would help a great deal
    Aircraft Proving Grounds
    http://www.rcaircraft.net/
    Information on the building and flying of Radio Control Aircraft.
    Site for hobbyist in the R.C. Aircraft modeling world.
  7. #7
    Join Date
    Aug 2002
    Daytona Beach, FL,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have built and flown three of these airplanes and they are great.
    Servos Ive always used JR 4721 ,2721, or 8411's. On my first one I had futaba 9202 and stripped them. As far as the Brison 4.2 its plenty witha 22x10 or 22x12 bolly or menz prop. I had one in mine it flew great, however I did put a brison 4.8 twin in my second and third and it was awesome.
    As far as the fix goes for the wing you are probably going to need the plans, and I dont have them. There is a firewall that is flush with the cowl and that fromer is needed in order to fix it. I think its on the plan. Or maybe Dennis can send you one I think its F-1. what you do is from the rear of the wing root where the stringers on the side end with that little former to support it, you run stringers I think there are two from the rear former to the inside of F-1. Then you sheet it to match the wing root. This is a pre-cut part in his kit. You then pull the wing out and sheet the underneath of it in the wing root to seal it off. Dont getting the sheeting real tight as you wont be able to get the wing on and off. That side is real delicate on that airplane. Squeeze it too much and it cracks very easily. On my last on, I actually cut a foam core to go inside of those and it worked great. Very strong and barely any weight added. Good luck with the fix. Its a great airplane. Im getting ready to order my second 40% 330s and it will be my 7th Carden. Enjoy!!
    Pete
  8. #8
    jw637362's Avatar
    Join Date
    Jan 2004
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @ Got Incon : I have sent you an email with some info. As soon as I receive the plans, i'll take them to the local kinkos and get them copied on their OCA large format copier. I am not sure what the TOC MOD for the plane is but I can get in contact with Carden and ask what it entails.
    I am not familier with the Brison myself but there website states :Suitable for planes from 19-32 lbs depending on wing loading. So you should be OK.
    I am fitting my Carden with a G-62 that I had on a 96" cap. That plane was running 24lbs wet and swung a 22-10 zinger prop. It did not have the power required for 3-D maneuvers but it did ok. That plane is gone now, due to the carburator coming loose on takeoff
    I am fitting my 300s with the following servos,
    Hitec HS-700BB Quarter scale for the rudder - setting up as pull pull of course with a bel crank. Great servo and reasonably priced!
    Hitec HS-605BB Dual bearings for the elevators - qty 2
    Hitec HS-605BB Dual bearings for the ailerons
    and standard Hitec for the throttle
    As far as the Carbon Spar goes. You can get in contact with Don's Hobbies out of Kansas.
    (785) 827-3222 * 1819 S. Broadway, Salinas, KS 67401
    I bought an aluminum spar and phenolic tube from him, very nice and helpful!
    I am sure he carries them but let me inform you that they cost a pretty penny.
    And if in the event you gain to much gravity on the plane during flight. It would be a great loss.
    The weight of the aluminum spar won't reflect the planes weight that much anyhow at anything over 15 lbs unless you are really into the 3-D stuff so I have been told..
    On the rudder servos. Are you sure it is not a servo for each elevator half? I only have two servo holes in my tail.......
    @PJFaller Thanks for the tips. I actually have thought about the foam forming then sheeting, starting cutting one out and decided to wait till I can actually get some photos of the fuselage building before I finish them in foam. Last resort thing.
    You can see in my photos up top that I have finished the fuselage less the wing formers, Their building was not up to my specks so I enhanced it a Tad for strength with the 1/8" Lite plywood side walls and engine mount.
    @everyone else. When I get the plans, I'll copy them and send to who ever needs them, not sure how much a tube costs USPS but can't be that much.
    Love to see some picts of completed Carden 300 30%'s planes as well on here.
  9. #9
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    jw637362, thanks for the offer.
    I can send you my information when every you are ready.
    My plane is a little battle worn but does fly great.
    After the modifications, if I don't sell it, I want to put a 100cc engine in it and fly!
  10. #10
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JW, thanks from the rest of us for taking the initiative to get the plans. I would be happy to pay for my share of the cost in getting a copy sent to me. Just let us know when it comes in.
    I'll send the pictures tomorrow.
    Thanks for the advice, I look forward to getting mine in the air.
    I do want to do some 3D with my 30%, so I'm trying to feel out whether the 4.2 will be big enough (it has a 23 x 10 on it now) or if maybe I should sell it and just pay the difference for a ZDZ 80 which I know will haul it vertically with authority.
    Thanks guys
    Good thread
  11. #11
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Speaking of which, if Carden has the plane plans in a cad model or a PDF, I can print out multiple copies on 48" plotter at work for no cost to us, if everyone would cover their shipping costs. (I didn't say that, if someone from work is reading..btw)
  12. #12
    jw637362's Avatar
    Join Date
    Jan 2004
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @Got Incon : Interesting Idea, that would be great. I'll call them up again and see if that would be feasible. If not, have to stick with the original plan.....no pun intended......
  13. #13
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can one of you guys confirm for me that a starting CG for this model would be the wingtube?
  14. #14
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a sachs 4.2 on mine and it is not enough for 3D. I am using a 24x8 and while it flies good, it doesn't have the ability to pull up strongly enough.
    ORIGINAL: Got Incon
  15. #15
    Join Date
    Aug 2002
    Daytona Beach, FL,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the wing tube for CG is perfect.
  16. #16
    Jemo's Avatar
    Join Date
    Dec 2001
    in, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a set of plans, but don't have a way to copy them.
    The CG on the plan calls for 1-1/8 forward of the wing tube.
    I have a 3W-75 on mine and the power is extremely good. I am looking for the 3D mods which weren't much, just moving the elevator hinge line up by about 3/4" and adding some to the rudder. I think this info was on a small sheet of paper so if I find it I will post it here.
    If I am over the hill, Why am I not picking up speed,?.
    http://charlotterc.com
  17. #17
    Jemo's Avatar
    Join Date
    Dec 2001
    in, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lets see if this will be readable
    Ok, not so good I see. I will email it ot anyone who needs it
  18. #18
    Join Date
    Aug 2002
    Daytona Beach, FL,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 3D mods to this plane make agreat difference. I was flying Carden's Cap 232 for a while as well but always liked the precision of the extra but the 3D capability of the Cap. When I built my second one I did the 3D mods and the plane was as 3D capable as my Cap but also tracked like an extra. It was awesome, BUT I would NOT tear the airplane apart to give the TOC 3D mod if it is already built. You will not be happy with the outcome trust me. It is a big job and I dont believe the way this aircraft is built, it would be feasible to accomplish this without losing some integrity to the tail. If you want a 3D capable extra do what I did BUILD Another one. The 330s that Carden has ins just incredible going to order my second soon. Good Luck.
    Pete
  19. #19
    Jemo's Avatar
    Join Date
    Dec 2001
    in, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pete,
    I agree the 3D mod was worth the effort. The plane flies great both for sequence and 3D.
    Mine weighed when built 21lbs 6oz. I replaced the landing gear with a carbon fiber gear from troybuilt. The weight is now under 21lbs, The gear is made for the Carden 35% Extra. At first glance it looks too big but fits up nicely.
  20. #20
    jw637362's Avatar
    Join Date
    Jan 2004
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Spoke with Dennis at Carden today - in re: "if Carden has the plane plans in a cad model or a PDF". It was an absolute no on this one. He is willing to take any calls from anyone who needs plans for this airplane or help. He charged me $20.00 for the plans and booklet and is shipping today which I found reasonable. The plane is now obsolete but will still sell the cowling, canopy, wheel pants and foam parts. I asked about a fuse kit and they stated no, they won't be available. That would a good reason to have the plans.
    I asked him about the TOC Mods for the plane and he stated that they were to little to even worry about in the constuction of the plane as PJFaller stated, to little to tear the airplane apart and redo.
    Something with the leading edges of the wings and rudder length I think.
    Anyway, Contact info.
    Carden Aircraft
    Carolyn and Dennis
    dgergits@cytechcis.net
    423-295-2295
    Jemo: That is one gorgeous plane......
    Hope to have some picts of mine finished in the next week!
  21. #21
    Jemo's Avatar
    Join Date
    Dec 2001
    in, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    jw637362
    The 3D mods are in post # 17
  22. #22
    Join Date
    Dec 2003
    , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jeff,
    I hope this helps you visualize some what was described to you.
    The last picture you can just barely see how a strip of balsa runs down the saddle starting at a piece of sheet cut to the shape of that saddle.
    It was almost impossible to get the angle I needed to get a picture of this.
ID:	158811   Click image for larger version.
ID:	158812   Click image for larger version.
  23. #23
    jw637362's Avatar
    Join Date
    Jan 2004
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @ Jemo, yea I realized that about the mods after I typed my info
    @ Got Incon, Those are great, I think I can figure it out with those. Not much to it. Just a plane sheet of balsa sticking to the 2 formers, then a some other additions for a little strength. We'll see, I'll post when done. Wish me luck.
  24. #24
    Join Date
    Aug 2002
    Daytona Beach, FL,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If anyone out there wants this airplane and Dennis has all the foam parts, cowl, and canopy, the airplane would be fairly east to build from the plans.
    Pete
  25. #25
    jw637362's Avatar
    Join Date
    Jan 2004
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have completed all of the framing and Wing Crows feet? I will start covering it tomorrow. Thanks for the picts of the area., After looking around the Fuselage, as PJfaller stated "the airplane would be fairly east to build from the plans" , it actually would, since the 30% is an obsoleted kit, I do not think Carden would really care. But if the kits are still in production, passing around plans to everyone to build from??????I don't think that would be ethical to utilize plans for that purpose.
    Anyway, hope this works.
    Jeff
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
