If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
Thread: 30% carden
  1. #1
    Join Date
    Sep 2004
    manly, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    30% carden
    Hi, I just bought a used 30% carden extra 300s, I have questions please tell me a good starting point for the throws, for the low and high rate. and what is the gas oil mix for a zenoah g62. thanks.
  2. #2
    wingburner's Avatar
    Join Date
    Jan 2003
    Beaverlodge, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 30% carden
    Carden 300s
    Elevator low 3/8"--high 5/8"
    Aileron low 5/8"--high 1"
    Rudder 30 degrees right and left
    Can't remember the ratio for the G62 but 40/1 good synthetic and you won't go wrong.
  3. #3
    Join Date
    Nov 2002
    Suwanee, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 30% carden
    The 30% Carden Extra is not a 3D plane, so set it up with whatever you feel comfortable with, it does take alot of elev to get it in air. It's a good IMAC type plane. It is a rather heavy frame compared with the newer 30%-33% planes out today. My recommendation would be to use something other than the G62, consider a lighter weight more powerful motor like the ZDZ80 or equivalent. Enjoy it.
  4. #4
    cstevec's Avatar
    Join Date
    May 2003
    Tappahannock, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 30% carden
    Dunno who built your 30%er jc but mine will 3D its little arse off. It is also elevator sensitive. When Dennis shipped these planes out, included in the box with the plans was an addendum sheet with toc mods. If the plane was built according to the addendum, it will 3D just fine. Of course if the guy who built it didn't know what he was doing......... Well.......
    My high rates are all there is, with 35% expo. Low rates are (in % of High) elevator 35%, Rudder 55% Aileron 58%, again with a generous amount of expo.
    I will admit that this plane does not do waterfalls as well as some of the newer planes available but considering mine weighs 17lbs 10 oz. with a ZDZ 60 I don't think it qualifies as either heavy or "not a 3D plane". Blenders with mine are a true thing of beauty & it will harrier around until the motor burns up, without the wing rock so many others suffer from. "Course I'm not so sure how its gonna perform with a G62 hangin' up front but then again, I don't have that in mine.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
