CG for 35 % Carden Cap 232
RE: CG for 35 % Carden Cap 232
I figure you need some better cg info. I just balanced mine per the factory specs. Flew it today for the first time. You want it 8 inches back from the root leading edge of your wing. This equals 5 inches back from the leading edge at the wing tips. with 2 people lift the plane at each wingtip 5in. back. make sure the tail is level and not tippping up or down while you check your cg. move yourbatteries to balance your plane. hope this helps
Forrest
Forrest
