Carden Aircraft Post threads here related to the Carden Aircraft line
carden 35% 260 liftoff
Reply
Old 01-14-2007, 04:48 PM
  #76
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: carden 35% 260 liftoff
at this point i had to relax and see where all my time has been going. i still have to deceide on a one or two piece cowl, but i,m heavly leaning to a one piece
ID:	597880   Click image for larger version
ID:	597881   Click image for larger version
ID:	597882   Click image for larger version
Bobt2 is offline
Old 01-14-2007, 10:46 PM
  #77
EJB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lookin' great Bob.
I'm also deliberating on the one or two piece for my 260.
Since you have the motor mounted was there any issue slipping the cowl off & on over the DA?
Thanks , Ed
EJB is offline
Old 01-15-2007, 07:37 PM
  #78
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ed, thats an issue i never thought of! tried it tonight and with a little wiggling it does go on and come off.
Bobt2 is offline
Old 01-21-2007, 07:18 PM
  #79
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i installed the stab tube hardpoints in the bottom instead of the top. i hate to see screw heads sticking out of the stabs
ID:	603545   Click image for larger version
ID:	603546   Click image for larger version
Bobt2 is offline
Old 01-27-2007, 04:39 PM
  #80
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have recently finished my 32% Carden Yak 54. I am so impressed with Carden kits, I would like to build the 35% Extra 260. I have a few questions.
1) I noticed the Carden Extra uses full length elevators on the horizontal stab. A few kits use the counter balance elevators similar to the Yak set-up. Is there any advantage or disadvantage with the full length elevators?
2) I have a set of MTW 75 canister mufflers. Will they fit and what is the header drop when using the DA100 engine?
3) I plan on using the DA100 engine with the SWB offset mount. What size spacers will I need?
4) What is the diameter of the spinner?
Thanks for the help.
I am enjoying this build thread.
Regards,
Steve K
swk550 is offline
Old 01-27-2007, 05:17 PM
  #81
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve,
The full scale 260 didn't have counter balances. Cardens 330s have them as does the full scale. Having flown both I don't see a difference but you might if using an older servo with less torque than todays servos.
Albert
as722 is offline
Old 01-27-2007, 05:27 PM
  #82
EJB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: swk550
Yes there is room for canisters but I don't know what the header drop would be. I'll be using the standard DA mufflers.
The DA 100 is 1" away from the firewall.
4-1/2"
Regards,
Steve K
EJB is offline
Old 01-28-2007, 12:42 AM
  #83
kevinc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Swk550, I am also building the Extra 260. I used the MTW 75 cans and used the 90mm drop. Works great with this plane. The spinner is a 4-1/2". I am new to building but have a great builder as a friend and this is turning out pretty nice.
Kevin
kevinc is offline
Old 01-30-2007, 12:24 PM
  #84
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the drop is about 4" i make my own headers from the kits and i use the k s rear exaust cans. the exaust exits the fuse just behind the wing tube.
Bobt2 is offline
Old 02-18-2007, 11:46 AM
  #85
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i havn't powsted in a while, so heres an update. as usual for me i went with a scale scheme. its the orignal patty with the white rudder
ID:	624131   Click image for larger version
ID:	624132   Click image for larger version
ID:	624133   Click image for larger version
Bobt2 is offline
Old 02-18-2007, 11:51 AM
  #86
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just to show what else i,m doing at the same time. i inherted my sons 40% carden 330s and deceided on a recover. tired of scale schemes and trying to use up lots of 1/2 rolls of monokote i copied and combined some schemes i've seen and liked.
Bobt2 is offline
Old 02-19-2007, 01:56 PM
  #87
Rcjake97
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont see that plane on their site?
can someone show it to me?
Rcjake97 is offline
Old 02-19-2007, 02:01 PM
  #88
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
theres no picture yet no their site. the specs are in the spec sheet tho.
Bobt2 is offline
Old 03-10-2007, 06:00 PM
  #89
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
justy waiting for a day to start painting. all bottom graphics are on. all flight servos are in [ hitec5945's on ail, 5955's on ele and a single 5955 on rudder]the weight as shown in the photos is 12 lb 2 oz, this is with the carden wing tube. that will be replaced with a carbon tube.
ID:	639394   Click image for larger version
ID:	639395   Click image for larger version
ID:	639396   Click image for larger version
Bobt2 is offline
Old 03-10-2007, 08:13 PM
  #90
zzw26n
zzw26n's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice job Bob!
If you would, could you explain your paint process; glass filler, primer, color, clear coat, etc?? DSP did a great thread on painting with the FG crew. And where do you paint? basement, garage, etc???
Ward
zzw26n is offline
Old 03-11-2007, 08:38 AM
  #91
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i don't want to get that deep into finishing here. it's been done before. however, the reason for the paint delay is that i'm working with a mfg and may be trying something new. stay tuned!
Bobt2 is offline
Old 04-01-2007, 02:24 PM
  #92
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a few more graphics and a balance check to go. i guess the first nice day it will fly. my son and i tried something new. water based poly u from jerry nelson. some colors matched well, others were piss poor imo. these were close but the royal blue on my other extra was wayyyyy off. its a whole new learning process for thinning and spraying. the up side is NO smell, dry in 15 min and for here on long island the more humidity the better it goes on.
Bobt2 is offline
Old 04-01-2007, 02:25 PM
  #93
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oops, forgot the pictures
ID:	654505   Click image for larger version
ID:	654506   Click image for larger version
ID:	654507   Click image for larger version
Bobt2 is offline
Old 04-01-2007, 02:36 PM
  #94
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm glad you went with the classis patty colors, I haven't seen one in a long time. Can't wait to see it fly.
Albert
as722 is offline
Old 04-01-2007, 05:50 PM
  #95
Scoubidou
Scoubidou's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What a beatiful plane bobt2[sm=thumbs_up.gif].
1) The pics show one rudder servo in the tail, right?
2) Did you put canisters
3) Please post the final weight when you have a chance.
Scoubidou is offline
Old 04-01-2007, 06:56 PM
  #96
Bobt2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its a single hitet5955 in the tail for the rudder. even with that and the lightened motor box, i,mpretty nose heavy. i switched out my ignition battery and saved 1 1/2 oz there and the lipos are going behind the radio compartment to get close. it looks like weight will be around 27 1/2 lbs.
Bobt2 is offline
Old 04-01-2007, 07:15 PM
  #97
Scoubidou
Scoubidou's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congratulation for your work and patience.
It will be a great and IMAC plane
Old 04-01-2007, 07:28 PM
  #98
hoverVT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice job, plane looks really nice. Tony
hoverVT is offline
Old 04-06-2007, 10:13 AM
  #99
kevinc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bobt2, Here is a pic of my 260. I am real close to maiden. Your plane looks great! Hope the pics go through. Im not sure how to get them on here, so I'll try with 1. More to follow if I figure this out. Kevinc
ID:	658148   Click image for larger version
ID:	658149   Click image for larger version
ID:	658150   Click image for larger version
ID:	658151   Click image for larger version
ID:	658152   Click image for larger version
kevinc is offline
Old 04-06-2007, 11:07 AM
  #100
hoverVT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin, Very nice sceme and super job, that is one of the nicest 260 I have seen. Tony
hoverVT is offline
Reply
Display Modes
