If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 156
  1. #51
    Join Date
    Oct 2003
    post falls, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: carden 35% 260 liftoff
    Thats what I did is add a piece. It looks fine.
    Kevin
  2. #52
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    did you start the wings first or are you ahead of me?
  3. #53
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    prepairing the wing cores is next. i start by laying out the ailerons{i,m going the tapered route} and the servo locations.then i install the servo hardpoints and cut the wire channel. last and most important, i make a pattern out of scrap foam so i can find the servo cutouts after sheeting
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	575525   Click image for larger version.
ID:	575526   Click image for larger version.
ID:	575527   Click image for larger version.
  4. #54
    Join Date
    Oct 2003
    post falls, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I started on the wings and getting some of the sheeting glued together. I need to decide on canisters. So Im not sure what to do with the motor box yet. Looks like your getting pretty far now.
    Kevin
  5. #55
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    only reason for canisters would be to fly imac. my home field has no noise issues and if it wasn't for imac i wouldn't waste the money or take the weight issue! the rpm gain just offsets the weight according to da
  6. #56
    RickP's Avatar
    Join Date
    Jan 2002
    Levittown, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob,
    Did you use the soldering Iron dohicky thing that Albert used to cut the slot for the servo wire? Looks pretty similar.
    RickP
  7. #57
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    rick, i made mine with some copper wire i had laying around
  8. #58
    Join Date
    Dec 2002
    MT Pocono, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob I see you twisted the wire on your soldering gun "jig". Have you had any issues with the "loop" not getting hot enough? Because by twisting the wire the "loop" becomes almost a heat sink and the part that's twisted will actually get hotter. I don't know how many watts your gun is but it's probably big enough that you whon't notice it.
    Albert
    Carden Aircraft
    Team JR
  9. #59
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    albert, you are correct, but at 140 watts it works.i do notice i only get a few cuts and the wire has to be replaced as it no longer transfers heat well.
  10. #60
    Levi_Jordan's Avatar
    Join Date
    Jul 2002
    Cheney, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice....
    Levi Jordan
  11. #61
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i deceided today was a mental health day.1st thing i did was pick up my wifes x-mas presents, which will insure my continued health. i installed both tube sockets in the fuse. at this point their tacked in. final glue will be added after the wings and stabs are fitted.i also assembled all the wing sheeting.
ID:	577073   Click image for larger version.
  12. #62
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    just an update. all bagging is now done, and the leading and trailing edges have been added. next will be setting the incidence's.
  13. #63
    Join Date
    Oct 2003
    post falls, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got all the lightning hole cut out on mine yesterday. I got 15 oz out of it using the same method as the guys on flying giants. Looks pretty cool. Everything is ready for bagging. I take it you havent ran into any issues with anything yet? This wait savings will help offset the canister wait. I will be using the MTW cans.
  14. #64
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sounds like it's comming along nicely! my shop is currently shut down till the 26TH. to much holiday things to do wishing for santa to bring the lipos and regulators.
  15. #65
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the next step is to set the wing incidences. i first glue the pad with blind nut into the wing root. then i screw in short screws with sharpened ends. the fuse is set to zero degrees and the wing is slid onto the tube. make sure the wing is held at zero and press onto the fuse side, this leaves impressions in the balsa side that are then drilled thru. the pads with screws are inserted from inside and the final check for zero is done. when all is perfect, glue one pad at a time in
ID:	585630   Click image for larger version.
ID:	585631   Click image for larger version.
ID:	585632   Click image for larger version.
ID:	585633   Click image for larger version.
  16. #66
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the second wing is in place at the magic 0.0 angle. the pads are glued one at a time. i leave off the top fuse cross braces until after this step is done. while the glue dries i glued the stab mounting pads in place
ID:	586004   Click image for larger version.
ID:	586005   Click image for larger version.
ID:	586006   Click image for larger version.
  17. #67
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the stabs are set next. i use small blocks of balsa tack glued to the fuse side to hold the leading edge in position while i drill the lower mounting holes. the plans call for a #8 sheet metal screw but i use a 6-32 bolt and blind nut.
ID:	586228   Click image for larger version.
  18. #68
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the hardest part of any build project, imo, is getting the pesky fin on straight! i changed the fin base from 1/4" to hard 1/8 to save weight. i use 3 methods to measure the fin, 1 is 90* to the tubes, 2 is crosshairs on the wall and last is a right angle on the firewall. when all is ready i glue with epoxy.
ID:	588160   Click image for larger version.
ID:	588161   Click image for larger version.
ID:	588162   Click image for larger version.
  19. #69
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i haven't posted in a while, but work is progressing. the flight surfaces are hinged and ready for final sanding. i,m now in the process of fitting the foward hatch and at the same time building the canopy frame.
ID:	595866   Click image for larger version.
ID:	595867   Click image for larger version.
  20. #70
    Join Date
    Nov 2002
    Laurel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lookin' good Bob, can't wait to see it fly.
    Dave
    Team JR
    jramericas.com
  21. #71
    Join Date
    Dec 2002
    MT Pocono, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob,
    Does the canopy get cut and glued on to rails or is it the same as the 330 ?
    Albert
    Carden Aircraft
    Team JR
  22. #72
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    albert, it is the same as the 330. glued to side rails and front and rear 1/4 balsa formers
  23. #73
    RickP's Avatar
    Join Date
    Jan 2002
    Levittown, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bob,
    One Peice coweling or two?
    Rick
  24. #74
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the cowl is next, i chose to use cardens method of mounting the cowl and everything fit perfectly. i attached the bottom first i installed the da 100 and the spinner first for alignment
ID:	597867   Click image for larger version.
ID:	597868   Click image for larger version.
ID:	597869   Click image for larger version.
ID:	597870   Click image for larger version.
  25. #75
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    after the bottom is tack glued in i added the top former and then the top of the cowl. after all the glass is tack glued to the formers i then add a bead of goop to the joints
ID:	597872   Click image for larger version.
ID:	597873   Click image for larger version.
ID:	597874   Click image for larger version.
ID:	597875   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
