If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 126 to 150 of 156
  1. #126
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Boisbriand, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: carden 35% 260 liftoff
    Thanks for the photos Bobt.
    There is plenty of room to fit tuned pipes in that plane.
    I have looked at the 35% Dalton and i prefer to go with Carden even it's not scale. The Carden plane looks like a big pattern plane with its strechy tail moment.. It might explains why they fly so good?
    Daniel
    Seneca Engineering
    http://www.seneca.ca/
  2. #127
    RobT's Avatar
    Join Date
    Sep 2003
    Syosset, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I took Dad's 35% 260 through the Unlimited Sequence again this weekend, and then played some 3D with it. If I had to go back to a 35% due to cost / transportation I would order one of these in a second and not look back. It would be competitive in any class no questions asked. It goes though a sequence faster than a 40%, however it does it as smooth and easy. Rollers seem easier with this than with my 40% 300 . . . Is that setup ? ? If so where??
  3. #128
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello robt
    Thanks for the IMAC flight review. Can you do the unlimited sequence under 50% throttle with the DA-100 on canisters or you need to play in 75%-100% throttle for specific figures like vertical snaps for those windy days?
    Daniel
    Seneca Engineering
  4. #129
    RobT's Avatar
    Join Date
    Sep 2003
    Syosset, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dan,
    The real question will be how much throttle will be needed on a hot summer day! But as of now at sea level on a 70 degree day I think I could go through unlimited with a 70% restriction on throttle.
    Rob
  5. #130
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, no need for tuned pipes in that plane I'll go with canisters .
    Daniel
    Seneca Engineering
  6. #131
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    heres a picture of it on the flight line sitting next to my reconditioned 40% 330
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  7. #132
    zzw26n's Avatar
    Join Date
    May 2004
    Shelby Twp., MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sweet looking ............
  8. #133
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    latest update, somewhere between 40-50 flights. still pulls to the canopy on long uplines so i,m going to increase to downthrust even more and i,m going to try moving the cg back a little so i need less down when inverted. still very pleased with the plane. they say it takes 100 flight to really trim it just right.i,m starting to believe it!
  9. #134
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I know what mean. Most of pilots do not take the time to trim their planes and fights againts it to fly straight. Only IMAC fliers understand how it's important to get a trimmed plane to fly good sequences.
    Daniel
    Seneca Engineering
  10. #135
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys
    I am building mine and the recommended ailerons dimensions are HUGE with 5'' 3/4'' at the root and 4''1/2 at the tips. Are they overkill or may i reduce it to 5'' a the root and 4'' at the tip?? I'll fly mostly IMAC.
    Daniel
    Seneca Engineering
  11. #136
    swk550's Avatar
    Join Date
    Apr 2003
    houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used straight ailerons at approx. 4.75 in width. The straight ailerons have an almost constant thickness at the hinge line. I did not need any matchboxes for the two aileron servos.
    swk550
  12. #137
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice color scheme!
    Seneca Engineering
  13. #138
    RobT's Avatar
    Join Date
    Sep 2003
    Syosset, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Do not second guess Dennis . . . just use less throw.
  14. #139
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello
    I decided to go with taper ailerons 5 3/4 at the root and 4'' at the tip.
    One 3/8'' balsa sheet do not allow more than 40 degres throw on the ailerons. Did you use 2 sheets to get more throw or is 40 degres enough for IMAC and 3D?
    Daniel
    Seneca Engineering
  15. #140
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i havn't checked in in a while, working on my 40%300. no, you do not need more throw on the ailerons.built as per the plans is going to be plenty
  16. #141
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys
    My Extra is almost finished and i am ready to install the rudder servo and receiver plate under the canopy. How does it balance with the DA-100 on canisters? I plan to use JR8711 pull-pull setup. Where did you put the choke+throttle servos?
    Daniel
    Seneca Engineering
  17. #142
    Join Date
    Nov 2002
    Laurel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Daniel,
    If there is any way to get that 8711 in the tail I'd recommend it. Increased authority, easier installation, no issues with slack lines, less costly- just so many reasons. I have two 8611a servos in the tail of my 40pct Carden 300 and rudder authority is very strong. I'm so glad I went that way instead of pull-pull.
    Dave
    Team JR
    jramericas.com
  18. #143
    Join Date
    Dec 2002
    MT Pocono, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: DMichael
    Daniel,
    Dave
    Good point !
    Carden Aircraft
    Team JR
  19. #144
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Unfortunately, the plane is covered and there is not enough plywood to install the rudder servo in the tail.
    I'll check it and see from there..[]
    Seneca Engineering
  20. #145
    Scoubidou's Avatar
    Join Date
    Jul 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [8D]
    Seneca Engineering
  21. #146
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i have a single hitec 5955 in the tail for rudder. tons of rudder power. mine is a little nose heavy. the throttle and choke servos are mounted just behind the firewall on a plate under the motor box. my ignition battery is mounted on top of the fuel tank. my reciever, 2 lipos, and 2 voltage regulators are mounted in the fuse behind the wing.it's still my favorite 35%plane! dave has flown it and will back that up!
  22. #147
    T. Bob's Avatar
    Join Date
    Feb 2002
    Munster, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bobt2
    The scheme totally kicks ass.
    Item Name: Item ID: 807535 Hitec HS-5625MG
    Ontario Buyer Poor 01/03/2012 Item ID: 807535 Hitec HS-5625M
  23. #148
    Join Date
    Feb 2005
    ASKER, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Bobt2
    Thank you for all the info.
    It look like your model was a little nose heavy. Did you maiden with the recommended CG?
    Where do you think your CG is now in relation to the recommendation?
    I am building the same model and will try to get it in balance with a ZDZ100NG on tunedpipes.
    Tor
  24. #149
    Join Date
    Feb 2004
    Lindenhurst, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i always test fly at the recomended c/g or a little nose heavy. it,s still a tad nose heavy. i moved it back a bunch but i didn't like the way it flew there. i must have 150 flights on it now and i still love it. however, i now have 7 flights on my new carden 40% 300 so the 260 is going to take a back seat to that for now.
  25. #150
    Join Date
    Nov 2002
    Laurel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, I can confirm that Bob's 35% 260 flies great. I just have to come to grips with the fact that I'll never have enough time or money to have all the planes I want and fly them!
    But that 40% 300 - Wow. I just put 5 more flights on mine yesterday with the 2008 sequence and I am just grinning ear to ear.....
    Tor- you shouldn't have any problems getting yours to balance with the ZDZ100 and tuned pipes. I have a Radiocraft Extra of the same size with just standard mufflers (noise diverters) and balance is no issue at all.
    Dave
    Team JR
    jramericas.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
