Carden Aircraft Post threads here related to the Carden Aircraft line
40% 260 on a Diet
Reply
Old 01-09-2007, 09:52 PM
  #126
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 40% 260 on a Diet
Is that bondo you used around the vertical fin fairing ?
Albert
as722 is offline
Old 01-09-2007, 10:15 PM
  #127
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: as722
Albert
No Albert its not bondo, its like mud that you put on drywall, except it the lite stuff. Home Depot sells it..... I'll look up the name later and let you know.....
(Lite Spackle found at Home Depot)
260 Man is offline
Old 01-10-2007, 05:21 PM
  #128
Matt_McCarty
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is an awsome build....keep us posted!
Matt_McCarty is offline
Old 01-12-2007, 08:20 AM
  #129
Desertrat
Desertrat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey George, do you have any more pictures of what you guys did to lighten up the wings and stabs? What did you use to pattern out the drill holes on the stabs?
Roger
Desertrat is offline
Old 01-13-2007, 02:22 AM
  #130
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Roger,
The wings have not been done as of yet. The stabs pattern were drawn (laid up) on the foam and then cut (drilled) out. There was no pre defined pattern...
ID:	596728   Click image for larger version
260 Man is offline
Old 01-13-2007, 02:24 AM
  #131
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
8 lbs 7 oz as she sits in this photo....
Cowl
Canopy
Landing Gear (Main and Tail)
260 Man is offline
Old 01-14-2007, 01:55 AM
  #132
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DA 100 installation tonight.......... Notice the weight of the bolts and the 2.5 deg right thrust in the mount...
Needless to say the aluminum bolts were used to mount the engine....
ID:	597461   Click image for larger version
ID:	597462   Click image for larger version
ID:	597463   Click image for larger version
ID:	597464   Click image for larger version
ID:	597465   Click image for larger version
260 Man is offline
Old 01-14-2007, 12:22 PM
  #133
gbrod
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a learning experience for me, great work, keep us informed.
My Carden 260 is at 39.3 lbs and it flyes like a dream with a DA 150.
Happy flying
George
gbrod is offline
Old 01-14-2007, 02:43 PM
  #134
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
260 man,
If it doesn't balance and or doesn't have enough power with the 100 will it be strong enough for a 150 ?
Albert
as722 is offline
Old 01-14-2007, 03:30 PM
  #135
sailing1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
260 Man,
Could you tell me where to pick up the aluminum mounting bolts.
PS really enjoying the build thread.
sailing1 is offline
Old 01-14-2007, 07:22 PM
  #136
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: as722
260 man,
Albert
Yep, but it will fly just fine on the 100..............
260 Man is offline
Old 01-14-2007, 07:30 PM
  #137
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sailing1
260 Man,
Aluminum Fasteners supply Inc
239-643-4551
PN 1448HHB205 (2024-T4)
260 Man is offline
Old 01-14-2007, 07:32 PM
  #138
260 Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On its wheels with motor in and spinner, prop, ignition, throttle servo all installed it sits at 16 lbs 6.4 oz..........Kavan Tires, Titanium Axles
ID:	598003   Click image for larger version
ID:	598004   Click image for larger version
260 Man is offline
Old 01-14-2007, 08:03 PM
  #139
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Albert
The C/G as it sits now with power plant, prop and spinner installed is @ 2.5" behind former 2, this means I will probably be placing some of the radio gear behind the C/G to get it balanced.
sensei is offline
Old 01-14-2007, 09:27 PM
  #140
Desertrat
Desertrat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 260 Man
Roger,
Thanks George, looking forward to seeing what you guys do with the wings.
Stay warm!
Old 01-14-2007, 11:12 PM
  #141
RC_Pattern_Flyer
RC_Pattern_Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess what we did not consider is that fat that you would have to mount the 100 urther forward because of a shorer crank.. therefore, more engine weight further forward to help compensate for the small engine.
Good for you guys...
Talk to you later!!
Chuck
RC_Pattern_Flyer is offline
Old 01-15-2007, 05:22 AM
  #142
rcplanefan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
George - do you worry about the aluminum mount bolts galling in the steel nuts? I've been thinking of using titanium bolts for this application basically to eliminate the possibility of them galling (and then not being removable!). Obviously, if I could use aluminum, I would from both a cost and weight standpoint. Thoughts?
Thanks!
Ken
rcplanefan is offline
Old 01-15-2007, 01:50 PM
  #143
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aluminum to aluminum usually locks up unless you use anti seize lubricant generally used in full scale applications. Aluminum to steel with silicone won't pose as a problem.
Bob Sawyer
sensei is offline
Old 01-15-2007, 04:47 PM
  #144
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2.5" behind F-2 is 1/4" in front of the leading edge of the wing. I'm assuming you meant F-3, if so 2.5" behind F-3 would be 1 7/8" in front of the recomended CG which is way nose heavy. If you are balancing 2.5 behind F-2 you'll probably be placing all of the radio gear and the kitchen sink behind of the recomended CG.
Albert
Quote:
ORIGINAL: sensei
Hello Albert
as722 is offline
Old 01-15-2007, 10:37 PM
  #145
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, like I said, 2.5" behind F2 where the cowling meets the fuse, also with the 4 servos in the tail and the horizontal stab in place, along with batteries behind the canopy this will be a stroll in the park.
Bob Sawyer
sensei is offline
Old 01-15-2007, 11:12 PM
  #146
AU cary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is awsome, i havent been on RCU in a while and this is the kind of stuff that gets my blood running all over again. awsome job man!
AU cary is offline
Old 01-16-2007, 04:06 PM
  #147
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, ok !
Quote:
ORIGINAL: sensei
Bob Sawyer
as722 is offline
Old 01-16-2007, 10:24 PM
  #148
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Albert,
The recommended C/G is 11.3" behind F2 and this thing balances at 2.5" behind F2 equaling 8.8" in front of the C/G as it sits Ok, there is 1 LB 12 ozs. in tail feathers, servos and hardware at 60" behind the C/G; moving the C/G aft about 8.00" Because of the project target weight and power plant choice, the aft portion of the fuse had to be fabricated very light or the recommended C/G would have been unattainable without led in the nose; killing the target weight in the first place. Remember that 60" arm is very sensitive to the C/G.
Bob
sensei is offline
Old 01-17-2007, 10:52 AM
  #149
RC_Pattern_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a prediction here, i bet we will find out as progress is made, i just dont understand why people cant help to keep the b.s. comments to themselves about ow it wont work or it gonna blow u or whatever. Let the man build, let the man fly, if it fails, you will have your turn to say i told you so...
BUT... if it flys great, makes weight, balances where it should, i bet no one has the balls to admit they were wrong.
Bob, wish it wasnt so cold, i know the garage has got to be freezing right now, not good to build in
To sunny skies and warmer weather, i anticipate the rest of your build.
Chuckles
Old 01-17-2007, 03:36 PM
  #150
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So are you saying that you put the whole airplane together, wings, stabs etc. and it balances at 2.5" behind F-2 or are you saying that your fuse balances at 2.5" behind F-2 ?
Albert
Quote:
ORIGINAL: sensei
Albert,
Bob
as722 is offline
Reply
Display Modes
