CG for a 40% Carden Cap232
AR
RE: CG for a 40% Carden Cap232
I've owned three of em'. Start with the CG about 1/2" in front of the leading edge of the tube and work your way back to the leading edge of the tube til' you get it to fly and land the way you like it. The first sign of being a little tail heavy on that plane will be in the landings. The tail will drop by itself and the plane will flair on approach before it's on the ground.
