Carden Aircraft Post threads here related to the Carden Aircraft line
Carden 35% Extra 300 Mid Wing
Reply
Old 11-25-2007, 07:02 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Carden 35% Extra 300 Mid Wing
Carden does not make a 35% Extra 300 Mid Wing airplane kit. Dennis sent me a 35% Extra 330 fuse with Extra 260 wings, motor box and landing gear. This will be my attempt to construct a 35% Extra 300 mid wing. Also I will be installing KS-1060 tuned pipes. First of all I had to mark on the plans the Extra 260 mid wing tube locations. I will be using the identical stab to wing center line offset as the Extra 260.
ID:	811297   Click image for larger version
ID:	811298   Click image for larger version
ID:	811299   Click image for larger version
ID:	811300   Click image for larger version
ID:	811302   Click image for larger version
swk550 is offline
Old 11-25-2007, 07:10 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Carden 35% Extra 300 Mid Wing
Saving Weight
I have built the Carden 32% Yak 54 and the 35% Extra 260. I have saved 14oz of weight so far by cutting lightening cut-outs in the plywood parts.
ID:	811308   Click image for larger version
ID:	811309   Click image for larger version
ID:	811310   Click image for larger version
ID:	811311   Click image for larger version
ID:	811313   Click image for larger version
ID:	811314   Click image for larger version
ID:	811315   Click image for larger version
ID:	811316   Click image for larger version
swk550 is offline
Old 11-25-2007, 07:16 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing & Balsa skins
I like to install the wing tube sockets with Gorilla glue. Make sure you tape off any openings so when the glue foams and expands it does not get on the wing core surfaces.
ID:	811320   Click image for larger version
ID:	811321   Click image for larger version
ID:	811322   Click image for larger version
ID:	811323   Click image for larger version
swk550 is offline
Old 11-25-2007, 07:19 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Framing up the fuselage
ID:	811325   Click image for larger version
ID:	811326   Click image for larger version
ID:	811327   Click image for larger version
ID:	811328   Click image for larger version
swk550 is offline
Old 11-25-2007, 07:35 AM
Bashedit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SWK,
I've been thinking about asking Carden if they would do that, you're one step ahead of me! I prefer the looks and longer moment arms for precision flight. Assme kit price same as standard 35%er? Looking forward to watching your progress on this!
Bashedit
Bashedit is offline
Old 11-25-2007, 10:54 AM
Leardriver
Leardriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good luck with your project but you might have made a little less work for yourself if you bought a 260 kit and a 330 turtledeck and canopy. Either way..very cool and good luck.
Leardriver
Leardriver is offline
Old 11-25-2007, 11:08 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Landing Gear Plate
ID:	811410   Click image for larger version
swk550 is offline
Old 11-25-2007, 02:30 PM
EJB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two questions:
-How about just raising the wings on the 300 to "midwing"...woudn't that work?
-What's the difference between the 300 & 260 wings?
EJB is offline
Old 11-28-2007, 08:14 PM
Buzzed
Buzzed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you order a "new" kit the 330 and 260 use the same wings. BUZZZZZZZZZZZ
Buzzed is offline
Old 11-28-2007, 09:31 PM
zzw26n
zzw26n's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: swk550
What did you use for the floor? black laminate?
zzw26n is offline
Old 11-28-2007, 09:45 PM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 1/4" grey depron. It is fuel and heat resistant. An added plus is that it is light.
swk550 is offline
Old 12-09-2007, 02:22 PM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing Construction
ID:	822028   Click image for larger version
ID:	822029   Click image for larger version
ID:	822030   Click image for larger version
ID:	822031   Click image for larger version
ID:	822033   Click image for larger version
ID:	822034   Click image for larger version
ID:	822035   Click image for larger version
swk550 is offline
Old 12-09-2007, 02:25 PM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More Wing Construction
ID:	822045   Click image for larger version
ID:	822046   Click image for larger version
ID:	822047   Click image for larger version
ID:	822048   Click image for larger version
ID:	822050   Click image for larger version
ID:	822051   Click image for larger version
swk550 is offline
Old 12-09-2007, 02:27 PM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stab Construction
swk550 is offline
Old 12-09-2007, 02:29 PM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Turtle Deck Construction
swk550 is offline
Old 12-16-2007, 08:51 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tuned Pipe Installation
I am installing KS 1060 tuned pipes. The header is a 90mm flex drop style. I am keeping the installation as light as possible as the CG of the plane with aluminum tuned pipes tends to be tail heavy. The exhaust floor is 1/4" grey depron. I use depron on all of my Carden 35% airplanes. I try to keep at least 1/8" clearance between the pipe or canister. So far, I have never melted depron. I will epoxy coat all wood parts in the exhaust tunnel area. Also, it is a good idea to install the wing tube sockets in the fuse before you finish installing the bottom side pieces. I CA in the sockets and then follow up with a 1/8" radius fillet of milled fiberglass and epoxy on the inside of the plywood motor box. The black servo extension lead tube is from Gator RC. It is a lightweight paper material.
ID:	826846   Click image for larger version
ID:	826847   Click image for larger version
ID:	826848   Click image for larger version
ID:	826849   Click image for larger version
ID:	826851   Click image for larger version
ID:	826852   Click image for larger version
ID:	826853   Click image for larger version
swk550 is offline
Old 12-16-2007, 09:26 AM
as722
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the depron idea for the can tunnel, good luck with your project.
Albert
as722 is offline
Old 12-29-2007, 09:10 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tuned Pipe holders
I had to cut a slot on the top side of the tuned pipe holders to clear the exhaust outlets.
ID:	836341   Click image for larger version
swk550 is offline
Old 12-29-2007, 09:12 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stab
I like to use the plywood stab roots with tabs for lock-down to the side of the fuse. I will install a anti-rotation pin on centerline after I align the stabs and wings.
swk550 is offline
Old 12-29-2007, 09:18 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing Root Caps
I have been using 1/4-20 aluminum screws in the wing caps to hold-down to the fuse. I like to install a reinforcing disk on the inside of the root cap. Then I use nylon wing nuts inside of the fuse. I have made a wing root drilling template. All of my Carden wings are interchangeable.
ID:	836346   Click image for larger version
ID:	836347   Click image for larger version
ID:	836348   Click image for larger version
ID:	836349   Click image for larger version
swk550 is offline
Old 01-20-2008, 10:22 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Litening the Fuse and Rudder
I finally have some more time to build. I've added litening cut-outs to the fuse belly and the rudder. I was able to save 1.5oz weight on the fuse and 0.9oz on the rudder. I hope this will offer better CG placement for the batteries as the aluminum KS1060 tuned pipes will move the CG to the rear.
ID:	855798   Click image for larger version
swk550 is offline
Old 02-18-2008, 10:45 AM
T. Bob
T. Bob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any updates?
T. Bob is offline
Old 02-18-2008, 11:32 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
T.Bob
I just finished the plane and am doing final balance and battery installation. I will post some picture shortly.
Steve
swk550 is offline
Old 02-20-2008, 08:18 PM
T. Bob
T. Bob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Come on Stevie your killing us....
T. Bob is offline
Old 02-22-2008, 11:24 AM
swk550
swk550's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finished Carden 35% Extra 300 Mid Wing
Well, it's finished. I hope to maiden the plane this weekend.
Weight 28# - 0 oz
DA-100
Mejzlik 28-10 prop
Tru-Turn 4-1/2" spinner
KS 1060 tuned pipes
DA 90mm drop headers
Graphtech landing gear & tailwheel assy.
Two 2300 ma A123 Rx batteries
NoBS 2000ma 4.8V NiMh ignition battery
Spektrum AR9000 Rx
JR X9303 Radio
CG set at 1/4" ahead of the wing tube
Steve
ID:	885499   Click image for larger version
ID:	885500   Click image for larger version
ID:	885501   Click image for larger version
ID:	885502   Click image for larger version
swk550 is offline
Reply
Display Modes
