Carden Aircraft Post threads here related to the Carden Aircraft line
Fuel Proof
Old 07-08-2008, 03:42 PM
80stars
Default Fuel Proof
Will someone please give me a good method for fuel proofing the engine box and firewall that looks nice and clean. I don't want to paint it but thought about just spraying it with clear.
Doug
Old 07-08-2008, 06:05 PM
BBW Walt
BBW Walt's Avatar
Default RE: Fuel Proof
Here's the best I've found. Brush it on, 2 coat's. Looks real nice, seals very well. its very light, and for 8 bucks you'll get a guart that will do more plane's than you got time left on the planet to build.
MINWAX Fast Drying Polyurethane. I get it at Ace Hardware...
Old 07-08-2008, 10:41 PM
80stars
ORIGINAL: BBW Walt
Thanks Walt,
Ace is 3 blocks down the street.
Doug
Old 07-09-2008, 11:55 AM
Scoubidou
My Feedback: (17)
Scoubidou's Avatar
Ultracote/monokote. It's llight, cheap and work great.
Old 07-17-2008, 11:44 AM
ibow24
My Feedback: (10)
I like the Minwax polyurethane too.
I've also used Zpoxy finishing resing, thinned with rubbing alcohol...but I like the Minwax better.
Steve
Old 07-17-2008, 09:09 PM
80stars
ORIGINAL: Scoubidou
After this project I have decided no more Ultracote. Sure it is forgiving, but the finish and durability compared to Monokote is lousy. My 17 year old Cub covered in Mono looks better than my current unfinished project in Ultracote.
Old 07-24-2008, 10:29 AM
ibow24
My Feedback: (10)
If it's been a few years since you used Monokote you will be very disappointed with it. Especially the black. It's pretty much unusable.
Of course, I quit Monokote a few years ago because of this, perhaps they fixed the problems since I've switched over to Ultracote.
Steve
Old 07-24-2008, 07:15 PM
as722
I mix clearcoat at about 1 to 1 and brush it on after I'm done covering. I make sure to go over the monokote "overlap" this ensures that the oil will not get under the covering. I do however like walt's idea and will try it on my next project.
Albert
Old 08-06-2008, 08:50 AM
SLINGSHOT-RCU
SLINGSHOT-RCU's Avatar
I use monokote on mine.
Old 08-10-2008, 03:23 PM
SunDevilPilot
SunDevilPilot's Avatar
Just cover it.....
However, polyurethane also works well.
SunDevilPilot
Old 08-31-2008, 10:27 PM
bawls
ORIGINAL: BBW Walt
This stuff is fuelproof?
I presume the spray can would work too?
