Carden Aircraft Post threads here related to the Carden Aircraft line
HANGAR 9 CARDEN YAK G-62
Old 12-08-2008, 06:08 PM
PLANE JIM
My Feedback: (109)
Default HANGAR 9 CARDEN YAK G-62
Hello-I am assembling a Yak with a G-62-has anyone had any experience with this set-up-thanks
Old 12-08-2008, 08:39 PM
karmann34
Default RE: HANGAR 9 CARDEN YAK G-62
Cool!
Does your G62 have mag or EI?
Old 12-09-2008, 02:25 AM
PLANE JIM
My Feedback: (109)
what does your's have??
Old 12-29-2008, 03:08 PM
RC GOLF
Evolution 58cc awesome
Old 12-30-2008, 05:36 AM
Axel40
That will be more power than it needs but sometimes you gotta go with what you got
I fly mine with a DL-50 and it's more than enough but I do have to push ignition batts and RX batts forward so the extra nose weight might actually help you.
I'm sure you'll love the plane though, it's a beauty!
Old 01-12-2009, 09:06 PM
PLANE JIM
My Feedback: (109)
Flew it this weekend with a magneto G-62 and it has better pull out of hover than my friends Yak with a DL50-and mine wieghs 19 lbs(a fat pig).
Old 01-27-2009, 02:39 PM
Colin Gardner
I have just finished my YAK and took it to the field on Sunday. I didn't fly because my test pilot didn't come but the model was well admired. I have put a CCRCpro 50cc in it with a 22*8 prop. It seems to be running at about 6500 and certainly plenty of pull. I use my G62 in a huge 9ft span 'Big Stik' which weighs nearly twice my YAK. It pulls that round the sky with the greatest of ease.
Anyway good luck with your YAK.
Old 02-05-2009, 09:22 PM
hanko
I have a 30% SD Yak with a G62. It certainly has the power, but it required 2 3000 MAH as far back in the cockpit as I could get them to get the CG close. So it is a fat pig, just under 20 lbs. I had a Quadra 50 in it and it was a real dog. Before that i started out with a fuji 50 in it, and i could never get that motor to run worth a dam. The next one I build assuming that sooner or later it will meat its demise, Im going with the DL 50.
Old 09-29-2009, 08:25 PM
wildhair
I have 5 flights on mine and it has a r-c g62 and running a mezlick 23/10 . one 2300a123 in the middle of the cockpit balanced perfect and flys extremly well. Lots of power
wildhair
