30% 300 mid wing rebuild
MN
RE: 30% 300 mid wing rebuild
ORIGINAL: A-Track
Looking nice Doug, you sticking with the same colors or ya going to recover the entire plane in something else?
Slick
Slick
I'll leave the wings and tail the same but change the fuse a bit.
Doug
MN
ORIGINAL: A-Track
Any update, you got it finished yet?
#35
MN
ORIGINAL: grant118
Looks real good. What do you use for covering and paint on the cowl? It looks like the paint matches toe covering well.
chris
chris
The covering is Ultracote and the paint on the cowl is Dupli Color in a rattle can from the auto parts store. True red Ultracote = Torch red Dupli Color paint
Doug
#36
MN
It's finished Three flights on it today all uneventful, that is if you don't count the left elevator control horn loosing a screw. Even with only half of an elevator it flys real nice. Overall weight with the DA50 and 1lb of lead on the nose (still 1/2" back on CG) came in at 17 lbs 6oz. I would say it feels like a brick, but that is because I have been flying a 12lb Extra 260 with the same DA50 setup. I would add another 6oz on the nose to tame the landings, it's too pitch sensitive. My plan is to put a DA85 on the front wich will solve any power/cg issues. I will be a wonderful plane to fly as is for all IMAC but will need more power to kick the thrill up a notch.
