nt-16 engine change help?
Hi i have a Fun factor 1/10 car with a NT-16 engine fitted as standard with it, the con rod has snapped, i have seen on Ebay a SH 18 engine from Hong Kong and they tell me it will fit in its place, is this right? and can i just swap over the clutch ,2 speed bell Etc?
RE: nt-16 engine change help?
The motor "should" fit, make sure it is a side exhaust and rotary carb.
Edit: All the SH .18 motors I see on ebay have a slide carb. You would be better to get an OS .18 cvrx with the 11j rotary carb. It is a durable motor and fits with no mods.
