CEN Racing This forum is to discuss all CEN Racing products.
CEN Matrix 1/8th scale
Reply
Old 05-22-2006, 06:21 PM
  #251
marzac2
marzac2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CEN Matrix 1/8th scale
I LOVE my new Matrix Race! By far, the best thing I have ever built in my life. And check out the cool paint job I did for it. It deserved it!
Zac
marzac2 is offline
Old 05-22-2006, 08:58 PM
  #252
RC30GTR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Holy **** thats dialed.... love that DNA thing
RC30GTR is offline
Old 06-25-2006, 03:30 PM
  #253
Jay-r
Jay-r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Cen Matrix RTR with RGX Matrix Body painted in GunMetal Gray.
ID:	482506   Click image for larger version
Jay-r is offline
Old 06-27-2006, 12:44 PM
  #254
Cainlord
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys, I am looking to get back to nitro with possibly another CEN Matrix buggy.
So my questions are this, what appear to be the must have upgrades right now with the CEN RTR buggy and where is a good place online to get them for the best price?
Also, what appears to be the starting race configuration setup right now? Will be running on a dry bumpy surface.
Finally, for the rotostart setup, can you use a power drill with the wand portion? Looking to get one that has the roto option already on it.
Cainlord is offline
Old 06-28-2006, 05:59 AM
  #255
gdc02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
5000/5000/2000
gdc02 is offline
Old 07-05-2006, 08:05 AM
  #256
majormorge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We have the same type of track condition that you have, I used 5000 Front, 7000 center, 3000 rear for diffs. Then I used the stock 2 hole piston in the shocks with 30wt oil in the front and 20wt in the rear, the proline crimefighters in the M3 compound really help with dry slick conditions. Anyway that is my setup.
majormorge is offline
Old 07-06-2006, 11:01 AM
  #257
Mike_Kazz
Mike_Kazz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[ul][*] Inside hole on all arms[*] CEN 30WT. oil all the way around[*] #2 pistons in front, #3 in rear[*] Blue CEN springs[*] CEN Diff oil- 5K, 5K, 2K (Mugen Seiki)[*] Panther Gator Tires MS[*] Wing level
[/ul]
This is my set-up for the Pro-Kit. This is what I'll run at the Roar Nats. I think it's a good set-up for most conditions and you can start from there... I don't try to modify my steering knuckles because I have too much steering as it is! LOL And that's a good thing! I'll have pics before the race!
Mike_Kazz is offline
Old 07-13-2006, 11:26 PM
  #258
jaywax
jaywax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I fixed the temp problem. I used the settings HSN: 3 3/4 turn out, LSN: 4 turn out, Mid: 1/2 turn from flush.
I start the motor a little lean on the HSN, I let it heat up pretty good then set it to these settings above. I take it slow around the track for one lap and it is good to go. I ran two tanks through and the temp were 262. The key is to let the motor warm up really well then set it to these settings. It may sound rich, but it has enough power to carry you through jumps and tight turns.
The buggy is durable as hell. I have had some tough landings and it did not blink an eye. The Matrix is solid as a rock.
jaywax is offline
Old 02-11-2007, 07:08 PM
  #259
egg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CAN ANY ONE HELP ME WITH SET UP OF THE MATRIX PLEASE.
egg is offline
Old 02-11-2007, 08:26 PM
  #260
RGX Blade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sure,
let us know at RGX Racing........
at:
Razorgrafix23@hotmail.com
or here...
the biggest "Noticeable Difference" is the diffs..."ALOT" of people are using either RGX difs or Kyosho diffs in the Buggies and the New RGX Diffs or Gene Hickerson's cross pin conversion
once changing to this configurations the cars and trucks seem to almost be able to drive themselfes....(in a manor of speaking of corse)
a good majority will run 5k in the front 5k in the center and 4k in rear.....
1 deg toe out
stock shock and camber link postions....
rear 3deg toe 2deg anti squat,hubs forward with long chasss center with standard chassis
#2 pistions all around 55wt oil in front.....40 to 45 in rear seems to get most in the "Ball Park"
anything else please letus know
RGX Blade is offline
Old 02-18-2007, 02:38 PM
  #261
jimf333
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
blade do i need head shims for odonell 30% on the rtr motor
jimf333 is offline
Old 02-18-2007, 02:40 PM
  #262
jimf333
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry it the matrix tr
jimf333 is offline
Old 02-18-2007, 06:13 PM
  #263
HeadRush ROB.21
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no you dont need shims
HeadRush ROB.21 is offline
Old 02-19-2007, 07:25 AM
  #264
RGX Blade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you run 30% YES.......!!!
don't run it without it...if running 20% there is no need....
you'll be fine....
if 30% you really should...the motor will be easier to tune...
and will have less problems...
may people will run it with out but there motors usually will go out faster.
as well the motor will suffer from "Detonation" ...and plugs will go "Faster"
sometimes as oon as you put them in and fire it up....as with the over compression the glow wire can and sometimes does break in the chamber...when this happens pretty much game over for the motor....
many will "Argue" these points...maybe it will happen? maybe it wont?
but then again i got my "Tutelage" from the Late Ron Paris himself.....
but then he was the "Formost" educated Individual on Nitro motors...
so yes!!! run a shim do not take a chance....if they say no they do not know better...
do not blow a 200.00 300.00 or more dollar motor jut because someone just bluts out sure no problem......
also if your not sure if a shim has already been added to the motor here is a way to check
get a piece of solder make a "Small L" shape at the end just big enough to get through the hole
and just over to the side past the "Dome" part of the cylinder and turn the motor over
(you should have it out of the car for all this)
let the piston Squash the Solder then take a pair of Calipers..take that mesurement...and let me know what it is.....
and i mention all of this as 90% of the motors are made "Over Seas".....where they "RARLEY" and i mean RARE!!! if they run anything over 25% nitro.......20% is the "Norm"
in America is one of the few countries where we will run 30% on as low as 8% lubricant!!!!
average here is 30% nitro on 11% lube....
so they usually will not need to run shims outside the U.S.
so once you have that mesurment let me know at: Razorgrafix23@hotmail.com
and i can let you know if it is needed or not to be on the "Safe Side"
here localy i see alot of people getting into the truggies...hey there cool right
well with all things there are new things to learn and do....so at 2 of the local tracks the
"Latest Rage in Motors" is the OPS radical...killer motor good to tune...good power band...
but Needs a "Shim"....needs to add a shim to it...so there motors and some of the other .28's are running real Eratic going hot cld hot cold....or not keep there tune reving high then dropping for no reason with alot of stalling....
in other words you already broke in th motor an got it tuned for the track...what happens after awhile bout a gallon or less......starts just "Acting Strange" for no apperent reason???
this is what they call the "Begining of the End"
some motors will last a gallon???????.......some only another tank....
but for no reason as well they will run hot with no punch...or will need to rasie the "Idle" more
or "Stalling more than usual".....sometimes going through more plugs than normal...
anyways i could go on about motor tuning and all but here they just slam people sometimes??
but let me know about that mesurment
Old 05-07-2007, 04:24 AM
  #265
morkendi
morkendi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am about to get the FRE for race season just because I want to be different than all the 8ight T drivers. Buying it used from someone who put aluminum bell crank and kyosho C hubs and steering knuckels on it. I know most people who race change out the diffs, so I was wondering what are the best ones to put in. Part number would help.
Also, is there any other problems I should RB S7 in it and was wondering how this mill would work in the matrix TR. I got a set of mugen 1.1 springs and Xray shoes I plan on puting in with a 13 tooth vented bell.
morkendi is offline
Old 05-07-2007, 10:45 PM
  #266
DahlELama
DahlELama's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You dont have to change out the diffs. Just get the cross pin conversion from Gene Hickerson. http://www.machines*********.com/
DahlELama is offline
Old 05-09-2007, 07:44 PM
  #267
egg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IM VERY HAPPY WITH MY CEN MATRIX BUGGY , I HAVE MADE SMALL ADJUSTMENTS TO IT . STARTED RACING AND HAVING A FAT TIME !!!!!!!!!!!!!!!!!!!!!!!!!!!!!. AND IT DRAWS ALOT OF ATTENTION.....MICK
egg is offline
Old 05-10-2007, 02:06 AM
  #268
CrazyMento
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CrazyMento is offline
Old 05-17-2007, 08:02 PM
  #269
green river rc
green river rc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have Matrix now also, I bought one from a racing buddy, it has only 1 race weekend on it and it still like new. I still need a radio and starter box to get it moving, I plan to let my son race it at Denos in Elizabethtown KY this summer.
green river rc is offline
Old 05-20-2007, 12:26 AM
  #270
ShaggyRobz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What would be the claimed top speed of the Matrix TR RTR?
ShaggyRobz is offline
Old 05-23-2007, 05:35 PM
  #271
sdgusa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guy's i just ordered my cen matrix rtr for my first buggy and just had a few questions. my first question is what percentage nitro fuel should i run and is there any certain brand? next is i ordered a medium odonnell glow plug is this a good choice of glow plug? and last what replacements parts in general should i keep around? thanks for your help can't what to get mine
sdgusa is offline
