In the search for more power, .28 ct4s
RE: In the search for more power, .28 ct4s
heh, Poor Judge.. he used the Stock Motor Mount, as he posted earlier
cheers for that. just wanted to check that i hadnt got the wrong ones for mine... they are too low for my .28, that was all.
Banned
not being a smart arse, my CT5 manual only shows one motor mount and one motor mount part number,,,,
SuperSS Absolutely VID please.....
Timmahh
Timmahh
ORIGINAL: nitrohead5300
Well I am glad to see someone with a cen onroad car finally try a big block in it.
The NX 15 is a big block engine.
rolland
#31
Banned
yes it is, just becuz it says 15 on it Dont be Fooled. its much bigger that its name implies.. kindof remind me of the old 73 buick regal i used to own... 455 Stage 1 w/oversized oilports,b&b on crank,stepped up cam,holly650dp,with the factory stock trany n gearing.. the nice thing is other than rims/tires, it looked bone arse stock like its lil bro 350. The Sweet thing is it was a Sleeper to boot. other than the lil "rough Idle" you could not tell anything was different. sounded like a stock 350 with a small cam. no big deal. heh used to make alota extra money on no big deal.....
back to the TaH... this "lil" 15 is no sloutch. thats for sure.
per CENs website,
1.5 horsepower
NX-15 Big Block Lighting Engine Big Block 2.5
3 Ports
Dual precision crank bearings
35000RPM
SG shafts
True ABC construction
Rear exhaust
Slide Carb
per CENs website,
1.5 horsepower
3 Ports
35000RPM
SG shafts
Rear exhaust
Slide Carb
#32
AB, CANADA
ORIGINAL: Timmahh
Timmahh
Timmahh
Anywho... How do you tell whether an RC engine is a BB or SB ??
#33
Banned
the displacement i think, bigger piston, crank crankcase ect.. most companys have the engines named for engine size, but i dont think cen follow this practice religously. '
at least thats how i understand it
Timmahh
Timmahh
#34
ORIGINAL: rolland
rolland
rolland
#36
Actually it is a .15 but it does have the same dimensions of other big blocks.
The term big blocks are referenced to the physical size of the block and not the displacement. There have been .12 big blocks made also.
What Nitrohead5300 probably should have said is a larger big block instead of "a big block".
The only reason I pointed out the fact that it was a big block is because some people have seen the .15 and assumed that it is a small block.
rolland
rolland
#37
AB, CANADA
ok, good to know. So it's kinda like how you can have a 318 big block or small block with the same displacement.
So, now, another question. Do most small blocks mount the same? And do most big blocks mount the same?
#38
u got it dustin - small blocks have a dedicated mounting hole pattern and dimensions that are smaller than big blocks' hole pattern. so yea, one set of mounts for big blocks, and another for small blocks. big blocks are all rear exhaust too.
#39
ORIGINAL: Timmahh
Nitro head. the NX-15 is a .25 motor at 1.5 horsepower. so it is a big block though on the bottom side of BB.
Timmahh
Timmahh
#40
and 2.5cc is .15ci Big block is what it says... BIG "BLOCK" block as in physical size of the crank case not displacement (thats how i understand it anyway)
Anyway i was gonna ask if theres any news on a video [8D]
#41
ORIGINAL: rolland
rolland
rolland
#44
nitrohead - the .15 cen bb engine has similar external dimensions, ie mounting holes, rear exhaust position, larger carb etc to a .26 or similar. the stroke and bore or capacity have nothing to do with whether an engine is a big block or small block.
#45
ORIGINAL: poor judgement
#46
#47
indeed the larger capacity motors do - therefore they need a larger block to fit it all in, u see? especially with the rear exhaust arrangement. i think we all know what we mean and are saying the same thing really...
vids vids vids! lets see it!
#48
I am glad that someone has tried a .28 in their Cen car . I am curious what kind of speed he will get out of this car with this .28. I know I am very satisfied with the performance I am getting with my outlaw with a .28 stuffed in it.
#50
Hey SSPower do you have any vids of your .28 ct4s?? I am really interested seeing your monster run!! I am not familar with the brand motor you are using, do you know what the power output of your motor is and its maxiumn rpms??
