noticed something at my exhaust
hi the side-exhaust of my engine is 2cm wide and my manifold is 1cm wide at the begining so what do you think will happen if i make the manifold as bid as the engine-exhaust
would it be better ore worse???
MA
RE: noticed something at my exhaust
it will help a little bit. if you widen the manifold opening to the same size as the engine port and make it nice and smooth, the exhaust will flow better and hopefully there will be a noticeable difference in performance.
CA
ORIGINAL: Vochlrupfer
Have fun!
Done this with all the manifolds i have. The results are that it will make your engine run cooler due to the faster exiting gasses, meaning you can lean out a little more. It will also add a few RPMs at the top end. Either way it is a good mod to do.
